Keyword reference
1WIRE
1Wire routines allow you to communicate with Dallas 1wire chips.
1WRESET , 1WREAD , 1WWRITE , 1WSEARCHFIRST , 1WSEARCHNEXT , 1WVERIFY , 1WIRECOUNT
CAN
CONFIG CANBUS , CONFIG CANMOB , CANBAUD , CANRESET , CANCLEARMOB , CANCLEARALLMOBS , CANSEND , CANRECEIVE , CANID , CANSELPAGE , CANGETINTS
Conditions
Conditions execute a part of the program depending on a condition being True or False
IF THEN ELSE END IF , WHILE WEND , ELSE , DO LOOP , SELECT CASE END SELECT , FOR NEXT
Configuration
Configuration commands initialize the hardware to the desired state.
CONFIG , CONFIG ACI , CONFIG ADC , CONFIG ADCX , CONFIG BCCARD , CONFIG CLOCK , CONFIG COM1 , CONFIG COM2 , CONFIG DACX , CONFIG DATE , CONFIG DMXSLAVE , CONFIG EEPROM , CONFIG EXTENDED PORT , CONFIG PS2EMU , CONFIG ATEMU , CONFIG I2CSLAVE , CONFIG INPUT , CONFIG GRAPHLCD , CONFIG KEYBOARD , CONFIG TIMER0 , CONFIG TIMER1 , CONFIG LCDBUS , CONFIG LCDMODE , CONFIG 1WIRE , CONFIG LCD , CONFIG OSC , CONFIG SERIALOUT , CONFIG SERIALIN , CONFIG SPI , CONFIG SPIX , CONFIG SYSCLOCK , CONFIG LCDPIN , CONFIG PRIORITY , CONFIG SDA , CONFIG SCL , CONFIG DEBOUNCE , CONFIG WATCHDOG , CONFIG PORTCOUNTER0 AND COUNTER1 , CONFIG TCPIP , CONFIG TWISLAVE , CONFIG SINGLE , CONFIG X10 , CONFIG XRAM , CONFIG USB , CONFIG DP , CONFIG TCXX , CONFIG VPORT CONFIG ERROR , CONFIG POWER REDUCTION , CONFIG EVENT SYSTEM , CONFIG DMA , CONFIG DMACHX , CONFIG SUBMODE , CONFIG POWERMODE , CONFIG XPIN
Conversion
A conversion routine is a function that converts a number or string from one form to another.
BCD , GRAY2BIN , BIN2GRAY , BIN , MAKEBCD , MAKEDEC , MAKEINT , FORMAT , FUSING , BINVAL , CRC8 , CRC16 , CRC16UNI , CRC32 , HIGH , HIGHW , LOW , AESENCRYPT , AESDECRYPT
DateTime
Date Time routines can be used to calculate with date and/or times.
DATE , TIME , DATE , TIME , DAYOFWEEK , DAYOFYEAR , SECOFDAY , SECELAPSED , SYSDAY , SYSSEC , SYSSECELAPSED
Delay
Delay routines delay the program for the specified time.
WAIT , WAITMS , WAITUS , DELAY
Directives
Directives are special instructions for the compiler. They can override a setting from the IDE.
$ASM , $BAUD , $BAUD1 , $BIGSTRINGS , $BGF , $BOOT , $CRYSTAL , $DATA , $DBG , $DEFAULT , $EEPLEAVE , $EEPROM , $EEPROMHEX , $EEPROMSIZE , $EXTERNAL , $HWSTACK , $INC , $INCLUDE , $INITMICRO , $LCD , $LCDRS , $LCDPUTCTRL , $LCDPUTDATA , $LCDVFO , $LIB , $LOADER , $LOADERSIZE , $MAP , $NOCOMPILE , $NOINIT , $NORAMCLEAR , $NORAMPZ , $PROJECTTIME , $PROG , $PROGRAMMER , $REGFILE , $RESOURCE , $ROMSTART $SERIALINPUT , $SERIALINPUT1 , $SERIALINPUT2LCD , $SERIALOUTPUT , $SERIALOUTPUT1 , $SIM , $SWSTACK , $TIMEOUT , $TINY , $WAITSTATE , $XRAMSIZE , $XRAMSTART , $XA , $CRYPT , $NOTRANSFORM , $FILE , $AESKEY , $XTEAKEY , $STACKDUMP , $NOFRAMEPROTECT , $FRAMEPROTECT
File
File commands can be used with AVR-DOS, the Disk Operating System for AVR.
BSAVE , BLOAD , GET , VER , DISKFREE , DIR , DRIVERESET , DRIVEINIT , LINE INPUT , INITFILESYSTEM , EOF , WRITE , FLUSH , FREEFILE , FILEATTR , FILEDATE , FILETIME , FILEDATETIME , FILELEN , SEEK , KILL , DRIVEGETIDENTITY , DRIVEWRITESECTOR , DRIVEREADSECTOR , LOC , LOF , PUT , OPEN , CLOSE , CHDIR , MKDIR , RMDIR
Graphical LCD
Graphical LCD commands extend the normal text LCD commands.
GLCDCMD , GLCDDATA , SETFONT , LINE , PSET , SHOWPIC , SHOWPICE , CIRCLE , BOX
I2C
I2C commands allow you to communicate with I2C chips with the TWI hardware or with emulated I2C hardware.
I2CINIT , I2CRECEIVE , I2CSEND , I2START I2CSTOP I2CRBYTE I2CWBYTE
IO
I/O commands are related to the I/O pins and ports of the processor chip.
ALIAS , BITWAIT , TOGGLE , RESET , SET , SHIFTIN , SHIFTOUT , DEBOUNCE , PULSEIN , PULSEOUT
Micro
Micro statements are specific to the micro processor chip.
IDLE , POWER MODE , POWERDOWN , POWERSAVE , ON INTERRUPT , ENABLE , DISABLE , START , END , VERSION , CLOCKDIVISION , CRYSTAL , STOP
Memory
Memory functions set or read RAM , EEPROM or flash memory.
ADR , ADR2 , WRITEEEPROM , CPEEK , CPEEKH , PEEK , POKE , OUT , READEEPROM , DATA 2 , INP , READ , RESTORE , LOOKDOWN , LOOKUP , LOOKUPSTR , CPEEKH , LOAD , LOADADR , LOADLABEL , LOADWORDADR , MEMCOPY , GETREG , SETREG
Remote Control
Remote control statements send or receive IR commands for remote control.
RC5SEND , RC6SEND , GETRC5 , SONYSEND
RS-232
RS-232 are serial routines that use the UART or emulate a UART.
BAUD , BAUD1 , BUFSPACE , CLEAR , ECHO , WAITKEY , ISCHARWAITING , INKEY , INPUTBIN , INPUTHEX , INPUT , PRINT , PRINTBIN , SERIN , SEROUT , SPC , MAKEMODBUS
SPI
SPI routines communicate according to the SPI protocol with either hardware SPI or software emulated SPI.
SPIIN , SPIINIT , SPIMOVE , SPIOUT
String
String routines are used to manipulate strings.
ASC , CHARPOS , UCASE , LCASE , TRIM , SPLIT , LTRIM , INSTR , SPACE , STRING , RTRIM , LEFT , LEN , MID , RIGHT , VAL , STR , CHR , CHECKSUM , CHECKSUM , HEX , HEXVAL , QUOTE , REPLACECHARS , STR2DIGITS , DELCHAR , DELCHARS , INSERTCHAR
TCP/IP
TCP/IP routines can be used with the W3100/IIM7000/IIM7010/W5100/W5200/W5300 modules.
BASE64DEC , BASE64ENC , IP2STR , UDPREAD , UDPWRITE , UDPWRITESTR , TCPWRITE , TCPWRITESTR , TCPREAD , GETDSTIP , GETDSTPORT , SOCKETSTAT , SOCKETCONNECT , SOCKETLISTEN , GETSOCKET , SOCKETCLOSE , SETTCP , GETTCPREGS , SETTCPREGS , SETIPPROTOCOL , TCPCHECKSUM , SOCKETDISCONNECT , SNTP , TCPREADHEADER , UDPREADHEADER
Text LCD
Text LCD routines work with normal text based LCD displays.
HOME , CURSOR , UPPERLINE , THIRDLINE , INITLCD , LOWERLINE , LCD , LCDAT , FOURTHLINE , DISPLAY , LCDCONTRAST , LOCATE , SHIFTCURSOR , DEFLCDCHAR , SHIFTLCD , CLS , LCDAUTODIM , LCDCMD , LCDDATA
Trig & Math
Trig and Math routines work with numeric variables.
ACOS , ASIN , ATN , ATN2 , EXP , RAD2DEG , FRAC , TAN , TANH , COS , COSH , LOG , LOG10 , ROUND , ABS , INT , MAX , MIN , SQR , SGN , POWER , SIN , SINH , FIX , INCR , DECR , DEG2RAD , CHECKFLOAT , MOD
Various
This section contains all statements that were hard to put into another group
CONST , DBG , DECLARE FUNCTION , DEBUG , DECLARE SUB , DEFXXX , DIM , DTMFOUT , EXIT , ENCODER , GETADC , GETKBD , GETATKBD , GETRC , GOSUB , GOTO , LOCAL , ON VALUE , POPALL , PS2MOUSEXY , PUSHALL , RETURN , RND , ROTATE , SENDSCAN , SENDSCANKBD , SHIFT , SOUND , STCHECK , SUB , SWAP , VARPTR , X10DETECT , X10SEND , READMAGCARD , REM , BITS , BYVAL , CALL , *IF ELSE ELSEIF ENDIF , READHITAG , SORT , XTEADECODE , XTEAENCODE
XMEGA
