CONFIG DATE
Configure the Format of the Date String for Input to and Output from BASCOM – Date functions
CONFIG DATE = DMY , Separator = char
DMY
The Day, month and year order. Use DMY, MDY or YMD.
Char
The character used to separate the day, month and year.
Old syntax :  / , - or . (dot).
Preferred new syntax : MINUS, SLASH or DOT.
Example:
Config Date = DMY, SEPARATOR=MINUS
The following table shows the common formats of date and the associated statements.
Country
Format
Statement
American
mm/dd/yy
Config Date = MDY, Separator = SLASH
ANSI
yy.mm.dd
Config Date = YMD, Separator = DOT
Britisch/French
dd/mm/yy
Config Date = DMY, Separator = SLASH
German
dd.mm.yy
Config Date = DMY, Separator = DOT
Italian
dd-mm-yy
Config Date = DMY, Separator = MINUS
Japan/Taiwan
yy/mm/dd
Config Date = YMD, Separator = SLASH
USA
mm-dd-yy
Config Date = MDY, Separator = MINUS
When you live in Holland you would use :
CONFIG DATE = DMY, separator = MINUS
This would print 24-04-02 for 24 November 2002.
When you line in the US, you would use :
CONFIG DATE = MDY , separator = SLASH
This would print 04/24/02 for 24 November 2002.
CONFIG CLOCK , DATE TIME functions , DayOfWeek , DayOfYear , SecOfDay , SecElapsed , SysDay , SysSec , SysSecElapsed , Time , Date
'name : megaclock.bas
'micro : Mega103
'[configure LCD]
'[now init the clock]
Config Date = Mdy , Separator = SLASH ' ANSI-Format
'The format is MM/DD/YY
Date$ = "11/11/00"
Time$ = "02:20:00"
'clear the LCD display
Cls
Home 'cursor home
_day = 1
