CONFIG CLOCK
Configures the timer to be used for the Time$ and Date$ variables.
CONFIG CLOCK = soft | USER [, GOSUB = SECTIC] [,RTC=rtc] [,RTC32=rtc32]
[,RTC=rtc] [,RTC32=rtc32] is only for ATXMEGA devices.
Soft
Use SOFT for using the software based clock routines.
You need to add an ENABLE INTERRUPTS statement to your code since the SOFT mode uses the timer in interrupt mode. The timer interrupt is enabled automatic but the global interrupt you need to enable yourself. While the compiler could enable the global interrupt automatic, you would not have control anymore when it is enabled when using multiple interrupts.
In general you enable global interrupts after all interrupts are setup.
For the SOFT mode you need to connect a special low frequency crystal with a value of  32768 Hz to the ASYNC TIMER oscillator pins.
Use USER to write/use your own code in combination with an I2C clock chip for example.
Sectic
This option allows to jump to a user routine with the label sectic.
Since the interrupt occurs every second you may handle various tasks in the sectic label. It is important that you use the name SECTIC and that you return with a RETURN statement from this label.
The usage of the optional SECTIC routine will use 30 bytes of the hardware stack. This option only works with the SOFT clock mode. It does not work in USER mode. [, GOSUB = SECTIC] is only for SOFT mode.
RTC
This option is only available for processors with an RTC (XMEGA).
This option sets the RTC  clock source.
Valid parameters are :
1KHZ_INT32KHZ_ULP      1 kHz from internal 32 kHz ULP
1KHZ_32KHZ_CRYSTOSC    1 kHz from 32 kHz Crystal Oscillator on TOSC
1KHZ_INT32KHZ_RCOSC    1 kHz from internal 32 kHz RC Oscillator
32KHZ_32KHZ_CRYSTOSC   32 kHz from 32 kHz Crystal Oscillator on TOSC
The 1KHz clocks will load the PER register with 1000-1 and the 32 KHz clock will load PER with a value of 32768-1.
The overflow mode is used and you can use the compare overflow if required.
Do not forget to enable the 32 KHz oscillator and the interrupts as shown in the Xmega example.
RTC32
This option is available for few XMEGA chips. You can use it instead of the RTC. In fact when a processor has an RTC32, it does not have an RTC.
You can not use both RTC and RTC32 together.
RTC32 only accepts one value : 1KHZ_32KHZ_CRYSTOSC
This also means that you must use/connect an external 32 KHz crystal.
When you use the RTC32, the battery back register VBAT_CTRL is initialized and setup.
When you use the CONFIG CLOCK (in soft or user mode) directive the compiler will DIM the following BYTE variables automatic :
_sec
_min
_hour
_day
_month
_year
The variables Time$ and Date$ will also be dimensioned. These are special variables since they are treated different. See TIME$ and DATE$.
Following a way to set Time$ and Date$ :
Date$ = "11/11/00"
Time$ = "02:20:00"
You can change the date format by using: Config Date = Mdy , Separator = "/"                           ' ANSI-Format
See CONFIG DATE
The _sec, _min and other internal variables can be changed by the user too.
But of course changing their values will change the Time$ and Date$ variables.
The compiler also creates an ISR that gets updates once a second. This works for AVR chips which can be asynchronously clocked from the TOSC1/2 pins.
TOSC1 = Timer Oscillator Pin 1
TOSC2 = Timer Oscillator Pin 2
For example the Timer/Counter 2 of an ATMEGA16 can be used as a Real Time Counter (RTC). The Timer/Counter 2 will then be asynchronously clocked from the TOSC Pin's. The Timer/Counter 2 can NOT be used for other tasks when configured in asynchronous mode.
noticeNotice that you need to connect a 32768 Hz crystal in order to use the timer in async mode, the mode that is used for the clock timer. You also need to enable interrupts because of the interrupt service routine.
When you choose the USER option, only the internal variables are created (like _sec , _min , _hour....).
With the USER option you need to write the clock code yourself (so the USER need to update for example the System Second or Secofday).
This means the one second clock must be generated by a "USER" source like a Timer which use the internal clock or an XTAL depending on the Xtal configuration.
There are so called "AVR Timer Calculator" online available where you input the clock frequency from xtal, which Timer you use (8 or 16 Bit) and the period you want to achieve (like 1 second or 1000ms) than it will give you number which you need to configure the timer.
You also configure the interrupt of the timer and then the program will jump to the timer interrupt routine where you can set the new system second.
Config Clock = User                                         'Use USER to write/use your own code
You also need to include the following labels with config clock = user:
Getdatetime:
'called when date or time is read
Setdate:
'called when date$ is set
Settime:
'scanned when time$  is set
Example for config clock = user in Bascom-Simulator
Following example use $sim so it can be used in Bascom-Simulator. It uses config clock in user mode.
The second tick is generated by Timer1 and the time updated in the Timer interrupt service routine.
You can run this example direct in Bascom Simulator and you need to CLICK ON RUN BUTTON (in the simulator) go to Interrupts Tab and hit theOVF1 BUTTON to simulate an Timer interrupt.
Then you will see how the program jump to the interrupt service routine and updates the time !!
The Simulator output give you following:
01.09.09
00:00:01
00:00:02
00:00:03
00:00:04
00:00:05
00:00:06
00:00:07
That's it !
$regfile = "m16def.dat"
$crystal = 12000000
$hwstack = 80
$swstack = 80
$framesize = 80
$baud = 19200
$sim                                                       'ONLY FOR SIMULATOR MODE !!!!
Dim second_tick As Long
Config Date = Dmy , Separator = .                           'Day.Month.Year
Config Timer1 = Timer , Prescale = 256
On Timer1 Timer_irq
Const Timer_preload = 18661                                 'Timervorgabe für Sekunden Takt
Enable Timer1
Enable Interrupts
Date$ = "01.09.09"
Time$ = "00:00:00"
Print Date$
       !NOP
End                   'end program
Timer_irq:                                                 'Timer1 IRQ (once per second)
Incr Second_tick
Time$ = Time(second_tick)
Timer1 = Timer_preload
Print Time$                                               'only for Bascom-Simulator
Settime:
Getdatetime:
Setdate:
Using a DS1307 with config clock
See the datetime_test1.bas example from the SAMPLES\DATETIME folder that shows how you can use a DS1307 clock chip for the date and time generation.
See also example below !
Using config clock with ATXMEGA
With ATXMEGA there are devices with 16-Bit RTC like ATXMEGA128A1 and 32-Bit RTC like ATXMEGA256A3B or ATXMEGA256A3BU.
ATXMEGA with 16-Bit RTC:
• Can be used with one of the two internal RC oscillator options or external 32.768kHz crystal oscillator
• The internal 32 kHz Ultra Low Power (ULP) is a very low power clock source, and it is not designed for high accuracy.
• If you want to use the internal 32Khz RC oscillator you need to enable it with config osc
Config Osc = Disabled , 32mhzosc = Enabled , 32khzosc = Enabled
ATXMEGA with 32-Bit RTC (for example ATXMEGA256A3B or ATXMEGA256A3BU):
• An external 32.768kHz crystal oscillator must be used as the clock source
• The 32-Bit RTC is combined with a Battery Backup System
Numeric Values to calculate with Date and Time:
• SecOfDay: (Type LONG) Seconds elapsed since Midnight. 00:00:00 start with 0 to 85399 at 23:59:59.
• SysSec: (Type LONG) Seconds elapsed since begin of century (at 2000-01-01!). 00:00:00 at 2000-01-01 start with 0 to 2147483647 (overflow of LONG-Type) at 2068-01-19 03:14:07
• DayOfYear: (Type WORD) Days elapsed since first January of the current year.
• First January start with 0 to 364 (365 in a leap year)
• SysDay: (Type WORD) Days elapsed since begin of century (at 2000-01-01!). 2000-01-01 starts with 0 to 36524 at 2099-12-31
• DayOfWeek: (Type Byte) Days elapsed since Monday of current week. Monday start with 0 to Sunday = 6
With the numeric type calculations with Time and date are possible. Type 1 (discrete Bytes) and 2 (Strings) can be converted to an according numeric value. Than Seconds (at SecOfDay and SysSec) or Days (at DayOfYear, SysDay), can be added or subtracted. The Result can be converted back.
TIME$ , DATE$ , CONFIG DATE, Memory usage, Date and Time Routines
The following ASM routines are called from datetime.lib
_soft_clock. This is the ISR that gets called once per second.
Example 1
'name : megaclock.bas
'micro : Mega103
'[configure LCD]
'[now init the clock]
Config Date = Mdy , Separator = / ' ANSI-Format
'The format is MM/DD/YY
Date$ = "11/11/00"
Time$ = "02:20:00"
'clear the LCD display
Cls
Home 'cursor home
_day = 1
Xmega Sample
' (c) 1995-2010, MCS
' xm128-RTC.bas
' This sample demonstrates the Xmega128A1 RTC
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64
$swstack = 64
$framesize = 64
Config Portb = Output
'First Enable The Osc Of Your Choice , make sure to enable 32 KHz clock or use an external 32 KHz clock
Config Osc = Enabled , 32mhzosc = Enabled , 32khzosc = Enabled
' For the CLOCK we use the RTC so make sure the 32 KHZ osc is enabled!!!
'configure the systemclock
Open "COM1:" For Binary As #1
Config Clock = Soft , Rtc = 1khz_int32khz_ulp ' we select the internal 1 KHz clock from the 32KHz internal oscillator
'the following clocks can be used to clock the RTC
' 1KHZ_INT32KHZ_ULP 1 kHz from internal 32 kHz ULP
' 1KHZ_32KHZ_CRYSTOSC 1 kHz from 32 kHz Crystal Oscillator on TOSC
' 1KHZ_INT32KHZ_RCOSC 1 kHz from internal 32 kHz RC Oscillator
' 32KHZ_32KHZ_CRYSTOSC 32 kHz from 32 kHz Crystal Oscillator on TOSC
Config Priority = Static , Vector = Application , Lo = Enabled ' the RTC uses LO priority interrupts so these must be enabled !!!
Enable Interrupts ' as usual interrupts must be enabled
Print Time$ ' print the time
Waitms 1000
'TO USE THE SECTIC in the sample you must use GOSUB=SECTIC in CONFIG CLOCK !!!
Sectic:
Toggle Portb 'optional toggle some leds when using the gosub=sectic option
Example 2
$regfile = "m128def.dat"
$hwstack = 80
$swstack = 80
$framesize = 160
$crystal = 8000000
$baud = 19200
Date$ = "11/11/05"
Time$ = "23:59:50"
 Waitms 500
 Print Date$ ; Spc(3) ; Time$
Example 3 (using DS1307 with Config clock)
' DateTime_test.bas
' This sample show how to use the Date-Time routines from the DateTime.Lib
' written by Josef Franz Vögel
$regfile = "m328pdef.dat"
$crystal = 12e6 '16MHz
$hwstack = 80
$swstack = 80
$framesize = 160
Const Clockmode = 1
'use i2c for the clock
#if Clockmode = 1
Config Clock = Soft ' we use build in clock
Disable Interrupts
#else
Config Clock = User ' we use I2C for the clock
'configure the scl and sda pins (using software I2C routines)
Config Sda = Portd.6
Config Scl = Portd.5
I2cinit
'address of ds1307
Const Ds1307w = &HD0 ' Addresses of Ds1307 clock
Const Ds1307r = &HD1
#endif
'configure the date format
Config Date = Ymd , Separator = - ' ANSI-Format
'This sample does not have the clock started so interrupts are not enabled
' Enable Interrupts
'dim the used variables
Dim Lvar1 As Long
Dim Mday As Byte
Dim Bweekday As Byte , Strweekday As String * 10
Dim Strdate As String * 8
Dim Strtime As String * 8
Dim Bsec As Byte , Bmin As Byte , Bhour As Byte
Dim Bday As Byte , Bmonth As Byte , Byear As Byte
Dim Lsecofday As Long
Dim Wsysday As Word
Dim Lsyssec As Long
Dim Wdayofyear As Word
' =================== DayOfWeek =============================================
' Example 1 with internal RTC-Clock
_day = 4 : _month = 11 : _year = 2 ' Load RTC-Clock for example - testing
Bweekday = Dayofweek()
Strweekday = Lookupstr(bweekday , Weekdays)
Print "Weekday-Number of " ; Date$ ; " is " ; Bweekday ; " = " ; Strweekday
' Example 2 with defined Clock - Bytes (Day / Month / Year)
Bday = 26 : Bmonth = 11 : Byear = 2
Bweekday = Dayofweek(bday)
Strdate = Date(bday)
Print "Weekday-Number of Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " is " ; Bweekday ; " (" ; Date(bday) ; ") = " ; Strweekday
' Example 3 with System Day
Wsysday = 2000 ' that is 2005-06-23
Bweekday = Dayofweek(wsysday)
Print "Weekday-Number of System Day " ; Wsysday ; " (" ; Date(wsysday) ; ") is " ; Bweekday ; " = " ; Strweekday
' Example 4 with System Second
Lsyssec = 123456789 ' that is 2003-11-29 at 21:33:09
Bweekday = Dayofweek(lsyssec)
Print "Weekday-Number of System Second " ; Lsyssec ; " (" ; Date(lsyssec) ; ") is " ; Bweekday ; " = " ; Strweekday
' Example 5 with Date-String
Strdate = "04-11-02" ' we have configured Date in ANSI
Bweekday = Dayofweek(strdate)
Print "Weekday-Number of " ; Strdate ; " is " ; Bweekday ; " = " ; Strweekday
' ================= Second of Day =============================================
_sec = 12 : _min = 30 : _hour = 18 ' Load RTC-Clock for example - testing
Lsecofday = Secofday()
Print "Second of Day of " ; Time$ ; " is " ; Lsecofday
' Example 2 with defined Clock - Bytes (Second / Minute / Hour)
Bsec = 20 : Bmin = 1 : Bhour = 7
Lsecofday = Secofday(bsec)
Print "Second of Day of Sec=" ; Bsec ; " Min=" ; Bmin ; " Hour=" ; Bhour ; " (" ; Time(bsec) ; ") is " ; Lsecofday
' Example 3 with System Second
Lsyssec = 1234456789
Lsecofday = Secofday(lsyssec)
Print "Second of Day of System Second " ; Lsyssec ; "(" ; Time(lsyssec) ; ") is " ; Lsecofday
' Example 4 with Time - String
Strtime = "04:58:37"
Lsecofday = Secofday(strtime)
Print "Second of Day of " ; Strtime ; " is " ; Lsecofday
' ================== System Second ============================================
_sec = 17 : _min = 35 : _hour = 8 : _day = 16 : _month = 4 : _year = 3
Lsyssec = Syssec()
Print "System Second of " ; Time$ ; " at " ; Date$ ; " is " ; Lsyssec
' Example 2 with with defined Clock - Bytes (Second, Minute, Hour, Day / Month / Year)
Bsec = 20 : Bmin = 1 : Bhour = 7 : Bday = 22 : Bmonth = 12 : Byear = 1
Lsyssec = Syssec(bsec)
Strtime = Time(bsec)
Print "System Second of " ; Strtime ; " at " ; Strdate ; " is " ; Lsyssec
Wsysday = 2000
Lsyssec = Syssec(wsysday)
Print "System Second of System Day " ; Wsysday ; " (" ; Date(wsysday) ; " 00:00:00) is " ; Lsyssec
' Example 4 with Time and Date String
Strtime = "10:23:50"
Strdate = "02-11-29" ' ANSI-Date
Lsyssec = Syssec(strtime , Strdate)
Print "System Second of " ; Strtime ; " at " ; Strdate ; " is " ; Lsyssec ' 91880630
' ==================== Day Of Year =========================================
_day = 20 : _month = 11 : _year = 2 ' Load RTC-Clock for example - testing
Wdayofyear = Dayofyear()
Print "Day Of Year of " ; Date$ ; " is " ; Wdayofyear
Bday = 24 : Bmonth = 5 : Byear = 8
Wdayofyear = Dayofyear(bday)
Print "Day Of Year of Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " (" ; Date(bday) ; ") is " ; Wdayofyear
' Example 3 with Date - String
Strdate = "04-10-29" ' we have configured ANSI Format
Wdayofyear = Dayofyear(strdate)
Print "Day Of Year of " ; Strdate ; " is " ; Wdayofyear
Lsyssec = 123456789
Wdayofyear = Dayofyear(lsyssec)
Print "Day Of Year of System Second " ; Lsyssec ; " (" ; Date(lsyssec) ; ") is " ; Wdayofyear
' Example 5 with System Day
Wsysday = 3000
Wdayofyear = Dayofyear(wsysday)
Print "Day Of Year of System Day " ; Wsysday ; " (" ; Date(wsysday) ; ") is " ; Wdayofyear
' =================== System Day ======================================
Wsysday = Sysday()
Print "System Day of " ; Date$ ; " is " ; Wsysday
Wsysday = Sysday(bday)
Print "System Day of Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " (" ; Date(bday) ; ") is " ; Wsysday
Wsysday = Sysday(strdate)
Print "System Day of " ; Strdate ; " is " ; Wsysday
Lsyssec = 123456789
Wsysday = Sysday(lsyssec)
Print "System Day of System Second " ; Lsyssec ; " (" ; Date(lsyssec) ; ") is " ; Wsysday
' =================== Time ================================================
' Example 1: Converting defined Clock - Bytes (Second / Minute / Hour) to Time - String
Print "Time values: Sec=" ; Bsec ; " Min=" ; Bmin ; " Hour=" ; Bhour ; " converted to string " ; Strtime
' Example 2: Converting System Second to Time - String
Lsyssec = 123456789
Strtime = Time(lsyssec)
Print "Time of Systemsecond " ; Lsyssec ; " is " ; Strtime
' Example 3: Converting Second of Day to Time - String
Lsecofday = 12345
Strtime = Time(lsecofday)
Print "Time of Second of Day " ; Lsecofday ; " is " ; Strtime
' Example 4: Converting System Second to defined Clock - Bytes (Second / Minute / Hour)
Lsyssec = 123456789
Bsec = Time(lsyssec)
Print "System Second " ; Lsyssec ; " converted to Sec=" ; Bsec ; " Min=" ; Bmin ; " Hour=" ; Bhour ; " (" ; Time(lsyssec) ; ")"
' Example 5: Converting Second of Day to defined Clock - Bytes (Second / Minute / Hour)
Lsecofday = 12345
Bsec = Time(lsecofday)
Print "Second of Day " ; Lsecofday ; " converted to Sec=" ; Bsec ; " Min=" ; Bmin ; " Hour=" ; Bhour ; " (" ; Time(lsecofday) ; ")"
' Example 6: Converting Time-string to defined Clock - Bytes (Second / Minute / Hour)
Strtime = "07:33:12"
Bsec = Time(strtime)
Print "Time " ; Strtime ; " converted to Sec=" ; Bsec ; " Min=" ; Bmin ; " Hour=" ; Bhour
' ============================= Date ==========================================
' Example 1: Converting defined Clock - Bytes (Day / Month / Year) to Date - String
Bday = 29 : Bmonth = 4 : Byear = 12
Print "Dat values: Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " converted to string " ; Strdate
' Example 2: Converting from System Day to Date - String
Wsysday = 1234
Strdate = Date(wsysday)
Print "System Day " ; Wsysday ; " is " ; Strdate
' Example 3: Converting from System Second to Date String
Lsyssec = 123456789
Strdate = Date(lsyssec)
Print "System Second " ; Lsyssec ; " is " ; Strdate
' Example 4: Converting SystemDay to defined Clock - Bytes (Day / Month / Year)
Wsysday = 2000
Bday = Date(wsysday)
Print "System Day " ; Wsysday ; " converted to Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " (" ; Date(wsysday) ; ")"
' Example 5: Converting Date - String to defined Clock - Bytes (Day / Month / Year)
Strdate = "04-08-31"
Bday = Date(strdate)
Print "Date " ; Strdate ; " converted to Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear
' Example 6: Converting System Second to defined Clock - Bytes (Day / Month / Year)
Lsyssec = 123456789
Bday = Date(lsyssec)
Print "System Second " ; Lsyssec ; " converted to Day=" ; Bday ; " Month=" ; Bmonth ; " Year=" ; Byear ; " (" ; Date(lsyssec) ; ")"
' ================ Second of Day elapsed
_hour = _hour + 1
Lvar1 = Secelapsed(lsecofday)
Print Lvar1
Lsyssec = Syssec()
_day = _day + 1
Lvar1 = Syssecelapsed(lsyssec)
Print Lvar1
Looptest:
' Initialising for testing
_day = 1
_month = 1
_year = 1
_sec = 12
_min = 13
_hour = 14
 If _year > 50 Then
 Exit Do
 _sec = _sec + 7
If _sec > 59 Then
 Incr _min
 _sec = _sec - 60
 _min = _min + 2
If _min > 59 Then
 Incr _hour
 _min = _min - 60
 _hour = _hour + 1
If _hour > 23 Then
 Incr _day
 _hour = _hour - 24
 _day = _day + 1
If _day > 28 Then
 Select Case _month
 Case 1
 Mday = 31
 Case 2
 Mday = _year And &H03
 If Mday = 0 Then
 Mday = 29
 Else
 Mday = 28
 Case 3
 Mday = 31
 Case 4
 Mday = 30
 Case 5
 Mday = 31
 Case 6
 Mday = 30
 Case 7
 Mday = 31
 Case 8
 Mday = 31
 Case 9
 Mday = 30
 Case 10
 Mday = 31
 Case 11
 Mday = 30
 Case 12
 Mday = 31
 End Select
 If _day > Mday Then
 _day = _day - Mday
 Incr _month
 If _month > 12 Then
 _month = 1
 Incr _year
If _year > 99 Then
 Exit Do
Lsyssec = Syssec()
Wsysday = Sysday()
Print Time$ ; " " ; Date$ ; " " ; Lsecofday ; " " ; Lsyssec ; " " ; Bweekday ; " " ; Wdayofyear ; " " ; Wsysday
'only when we use I2C for the clock we need to set the clock date time
#if Clockmode = 0
'called from datetime.lib
Dim Weekday As Byte
Getdatetime:
I2cstart ' Generate start code
I2cwbyte Ds1307w ' send address
I2cwbyte 0 ' start address in 1307
I2cwbyte Ds1307r ' send address
I2crbyte _sec , Ack
I2crbyte _min , Ack ' MINUTES
I2crbyte _hour , Ack ' Hours
I2crbyte Weekday , Ack ' Day of Week
I2crbyte _day , Ack ' Day of Month
I2crbyte _month , Ack ' Month of Year
I2crbyte _year , Nack ' Year
I2cstop
 _sec = Makedec(_sec) : _min = Makedec(_min) : _hour = Makedec(_hour)
 _day = Makedec(_day) : _month = Makedec(_month) : _year = Makedec(_year)
Setdate:
 _day = Makebcd(_day) : _month = Makebcd(_month) : _year = Makebcd(_year)
I2cwbyte 4 ' starting address in 1307
I2cwbyte _day ' Send Data to SECONDS
I2cwbyte _month ' MINUTES
I2cwbyte _year ' Hours
I2cstop
Settime:
 _sec = Makebcd(_sec) : _min = Makebcd(_min) : _hour = Makebcd(_hour)
I2cwbyte 0 ' starting address in 1307
I2cwbyte _sec ' Send Data to SECONDS
I2cwbyte _min ' MINUTES
I2cwbyte _hour ' Hours
I2cstop
#endif
Weekdays:
Data "Monday" , "Tuesday" , "Wednesday" , "Thursday" , "Friday" , "Saturday" , "Sunday"
