CONFIG COM2
Configures the UART of AVR chips that have a second extended UART like the M128.
CONFIG COM2 = baud , synchrone=0|1,parity=none|disabled|even|odd,stopbits=1|2,databits=4|6|7|8|9,clockpol=0|1
baud
Baud rate to use. Use 'dummy' to leave the baud rate at the $baud1 value.
synchrone
0 for asynchrone operation (default) and 1 for synchrone operation.
Parity
None, disabled, even or odd
Stopbits
The number of stopbits : 1 or 2
Databits
The number of databits : 4,5,7,8 or 9.
Clockpol
Clock polarity. 0 or 1.
Normally you set the BAUD rate with $BAUD or at run time with BAUD. You may also set the baud rate when you open the COM channel. It is intended for the Mega2560 that has 4 UARTS and it is simpler to specify the baud rate when you open the channel. It may also be used with the first and second UART but it will generate additional code since using the first or second UART will always result in generating BAUD rate init code.
Note that not all AVR chips have the extended UART. Most AVR chips have a UART with fixed communication parameters. They are : No parity, 1 stopbit, 8 data bits.
See Also
CONFIG COM1 , CONFIG COMx
'name :
'purpose : test for M128 support in M128 mode
'micro : Mega128
$regfile = "m128def.dat" ' specify the used micro
$baud1 = 19200
'By default the M128 has the M103 compatibility fuse set. Set the fuse to M128
'It also runs on a 1 MHz internal oscillator by default
'Set the internal osc to 4 MHz for this example DCBA=1100
'use the m128def.dat file when you wanto to use the M128 in M128 mode
'The M128 mode will use memory from $60-$9F for the extended registers
'Since some ports are located in extended registers it means that some statements
'will not work on these ports. Especially statements that will set or reset a bit
'in a register. You can set any bit yourself with the PORTF.1=1 statement for example
'But the I2C routines use ASM instructions to set the bit of a port. These ASM instructions may
'only be used on port registers. PORTF and PORTG will not work with I2C.
'The M128 has an extended UART.
'when CONFIG COMx is not used, the default N,8,1 will be used
Config Com2 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
'try the second hardware UART
Open "com2:" For Binary As #1
'try to access an extended register
Config Portf = Output
'Config Portf = Input
Print "Hello"
Dim B As Byte
Input "test serial port 0" , B
Print B
Print #1 , "test serial port 2"
Close #1
