FOR-NEXT
Execute a block of statements a number of times.
FOR var = start TO end [STEP value]
var
The variable counter to use
start
The starting value of the variable var
end
The ending value of the variable var
value
The value var is increased/decreased with each time NEXT is encountered.
• For incremental loops, you must use TO.
• For decremental loops, you must use a negative step size.
• You must end a FOR structure with the NEXT statement.
• The use of STEP is optional. By default, a value of 1 is used.
When you know in advance how many times a block of code must be executed, the FOR..NEXT loop is convenient to use.
You can exit a FOR .. NEXT loop with the EXIT FOR statement.
It is important that the if you use variables for START and END, that these are of the same data type. So for example:
Dim x, as byte, st as byte, ed as byte
FOR x = st TO ED ' this is ok since all variables are of the same data type
Dim x as Byte, st as Word, Ed as Long
FOR x = st TO ED ' this is NOT ok since all variables are of different data type.
The reason is that when the condition is evaluated, it will create a compare on 2 bytes, while you actually want to have a word since the end variable is a word.
A for next loop with an integer has an upper limit of 32766 and not 32767, the maximum value that fits into an integer.
This is done in order to save code space. Checking an overflow from 32767 to -32768 would cost extra code.
There are also other alternatives. You can use a Do.. Loop for example :
Dim Var As Byte
'code
 Incr Var
Loop Until Var = 10
There are various way to get the result you need.
EXIT FOR
'name : for_next.bas
'purpose : demo: FOR, NEXT
Dim A As Byte , B1 As Byte , C As Integer
For A = 1 To 10 Step 2
Print "This is A " ; A
Next A
Print "Now lets count down"
For C = 10 To -5 Step -1
Print "This is C " ; C
Print "You can also nest FOR..NEXT statements."
For A = 1 To 10
For B1 = 1 To 10
 Print "This is B1 " ; B1
Next ' note that you do not have to specify the parameter
Next A
