CONFIG LCD
Configure the LCD display and override the compiler setting.
CONFIG LCD = LCDtype , CHIPSET=KS077 | Dogm163v5 | DOG163V3 | DOG162V5 | DOG162V3 | ST7032 [,CONTRAST=value] [,BEFORE=0|1] [,AFTER=0|1]
BEFORE and AFTER. with a parameter value of 1 a sub will be called _lcdBefore and _lcdAfter
LCDtype
The type of LCD display used. This can be :
40x4,16x1, 16x2, 16x4, 16x4, 20x2, 20x4, 16x1a or 20x4A.
Default 16x2 is assumed.
Chipset
KS077
Most text based LCD displays use the same chip from Hitachi. But some use the KS077 which is highly compatible but needs an additional function register to be set. This parameter will cause that this register is set when you initialize the display.
CHIPSET
DOGM
The DOGM chip set uses a special function register that need to be set.
The 16 x 2 LCD displays need DOG162V3 for 3V operation or DOG162V5 for 5V operation.
The 16 x 3 LCD displays need DOG163V3 for 3V operation or Dogm163v5 for 5V operation
CHIPSET ST7032
This chip is used on I2C lcd's. It requires library Lcd_RX1602A5. See example 3 below.
CONTRAST
The optional contrast parameter is only supported by the EADOG displays. By default a value from the manufacture is used. But you might want to override this value with a custom setting.
The default values are :
- DOGM162V5 : &H74
- DOGM162V3 : &H78
- DOGM163V5 : &H7C
- DOGM163V3 : &H70
BEFORE
This is an optional parameter. A value of 1 will result in a call to a routine named _LCDBEFORE, each time LCD value|"text" is used.
This allows you as a user to turn off interrupts or perform other tasks.
AFTER
This is an optional parameter. A value of 1 will result in a call to a routine named _LCDAFTER, each time LCD value|"text" is ended.
This allows you as a user to turn on interrupts or perform other tasks.
When you have a 16x2 display, you don't have to use this statement.
The 16x1a is special. It is used for 2x8 displays that have the address of line 2, starting at location &H8.
The 20xA is also special. It uses the addresses &H00, &H20, &H40 and &H60 for the 4 lines. It will also set a special function register.
The CONFIG LCD can only be used once. You can not dynamic(at run time) change the pins.
When you want to initialize the LCD during run time, you can use the INITLCD statement.
The BEFORE and AFTER parameters can be used to call some user code just before data is shown on the LCD, and when finished.
For example, you could toggle a LED on/off. Or set some background light. Or disable interrupts before showing data, and enable interrupts afterwards.
You must use DECLARE SUB to declare the called labels. Or you may use normal labels and exit with RETURN.
See Also
CONFIG LCDPIN , CONFIG LCDBUS , INITLCD
Example1
'name : lcd.bas
' CURSOR, DISPLAY
'micro : Mega8515
$regfile = "m8515.dat" ' specify the used micro
$sim
'REMOVE the above command for the real program !!
'$sim is used for faster simulation
'note : tested in PIN mode with 4-bit
'These settings are for the STK200 in PIN mode
'Connect only DB4 to DB7 of the LCD to the LCD connector of the STK D4-D7
'Connect the E-line of the LCD to A15 (PORTC.7) and NOT to the E line of the LCD connector
'Connect the RS, V0, GND and =5V of the LCD to the STK LCD connector
Dim A As Byte
Config Lcd = 16x2 'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
' because it aint need the port pins !
Cls 'clear the LCD display
Wait 1
Wait 1
Wait 1
For A = 1 To 10
Wait 1 'wait a moment
For A = 1 To 10
Lcd "*" 'display this
Lcd "@" 'display this
Cursor On Blink 'show cursor
Display Off 'turn display off
Display On 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Fourth
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Cls 'select data RAM
_temp1 = 1 'value into ACC
Example2
' EADOG-M163.bas
' Demonstration for EADOG 163 display
' (c) 1995-2006, MCS Electronics
$regfile = "M8515.dat"
$crystal = 4000000
'I used the following settings
'Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0
'CONNECT vin TO 5 VOLT
Config Lcd = 16x3 , Chipset = Dogm163v5 '16*3 type LCD display
'other options for chipset are DOG163V3 for 3Volt operation
'Config Lcd = 16 * 3 , Chipset = Dogm163v3 , Contrast = &H72 '16*3 type LCD display
'The CONTRAST can be specified when the default value is not what you need
'The EADOG-M162 is also supported :
'Chipset params for the DOGM162 : DOG162V5, DOG162V3
Cls 'Dit maakt het scherm leeg
Locate 1 , 1 : Lcd "Hello World"
Locate 2 , 1 : Lcd "line 2"
Locate 3 , 1 : Lcd "line 3"
Example3
'name : LCD-RX1602A5.bas
'copyright : (c) 1995-2014, MCS Electronics
'purpose : demonstrates I2C LCD library
'micro : Mega88
'The used library was sponsored by Lab microelectronic GmbH
$regfile = "m88def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 32
$framesize = 64
const vmode = 3 ' 3V mode
$lib "Lcd_RX1602A5.lbx"
$lib "i2c_twi.lbx" ' use hardware twi or remark for software I2C
Config Twi = 100000 ' 100kHz
config lcd = 16x2 , chipset = st7032
config SCL=PORTC.5
config SDA=PORTC.4
I2cinit
lcd_reset alias portc.2 ' pin used for LCD RESET
lcd_light alias portd.7 ' pin used for back light
Config lcd_reset = Output ' Display Reset
Config lcd_light = Output ' Display Licht
lcd_light = 1 ' activate background LED
Lcd_reset = 0 ' RESET mode
waitms 100
Lcd_reset = 1 ' normal mode
initlcd ' init LCD
lcdcontrast 30 'a value between 30 and 40 works best at 3V
Cls
Locate 1 , 1 : Lcd "test"
Waitms 100 '
Example4
declare sub _lcdbefore()
declare sub _lcdafter()
config PORTB.0=OUTPUT
config LCD=16x2, before=1,after=1
CLS
LCD "test"
sub _lcdbefore()
set portb.0
end sub
sub _lcdafter()
 reset portb.0
end sub
