CONFIG EVENT SYSTEM
This statement configures the Xmega event routing.
CONFIG EVENT_SYSTEM = dummy, MUXx=MUX, QDx=QD, QDIx=QDI, QDIRMx=QDIRM,DIGFLTx=DIGFLT
The letter X is used to indicate that a value between 0 and 7 can be used. So there is MUX0, MUX1, MUX2,MUX3 etc.
The Event System is a set of features for inter peripheral communication. It enables the possibility
for a change of state in one peripheral to automatically trigger actions in other peripherals.
The change of state in a peripheral that will trigger actions in other peripherals is configurable in
software. It is a simple, but powerful system as it allows for autonomous control of peripherals
without any use of interrupt, CPU or DMA resources.
There are 8 multiplexers and 8 control registers. Register 0, 2 and 4 can be used for quadrature decoding.
MUX
There are 8 multiplexers, named MUX0-MUX7. The MUX is used to select an event source.There are many sources for events :
NONE : disabled, default
RTC_OVF : Real Timer overflow
RTC_CMP : Real Timer compare match
ACA_CH0 : analog comparator ACA, channel 0
ACA_CH1 : analog comparator ACA, channel 1
ACA_WIN : analog comparator ACA, window
ACB_CH0 : analog comparator ACB, channel 0
ACB_CH1 : analog comparator ACB, channel 1
ACB_WIN : analog comparator ACB, window
ADCA_CH0- ADCA_CH3 : ADCA channel 0-3
ADCB_CH0- ADCB_CH3 : ADCB channel 0-3
PORTA.0 - PORTA.7 : PORT A pin 0-7
PORTB.0 - PORTB.7 : PORT B pin 0-7
PORTC.0 - PORTC.7 : PORT C pin 0-7
PORTD.0 - PORTD.7 : PORT D pin 0-7
PORTE.0 - PORTE.7 : PORT E pin 0-7
PORTF.0 - PORTF.7 : PORT F pin 0-7
PRESCALER1, PRESCALER2, PRESCALER4, PRESCALER8, PRESCALER16, PRESCALER32, PRESCALER64,PRESCALER128,PRESCALER256,PRESCALER512,PRESCALER1024,PRESCALER2048,PRESCALER4096,PRESCALER8192,PRESCALER16384 : The clock divided by 1,2,4,8,16,32,64,128,256 etc.
TCC0_OVF  : Timer TC0 overflow
TCC0_ERR : Timer TC0 error
TCC0_CCA : Timer TC0 capture or compare match A
TCC0_CCB : Timer TC0 capture or compare match B
TCC0_CCC : Timer TC0 capture or compare match C
TCC0_CCD : Timer TC0 capture or compare match D
TCC1_OVF  : Timer TC1 overflow
TCC1_ERR : Timer TC1 error
TCC1_CCA : Timer TC1 capture or compare match A
TCC1_CCB : Timer TC1 capture or compare match B
TCC1_CCC : Timer TC1 capture or compare match C
TCC1_CCD : Timer TC1 capture or compare match D
Dito for TCD0, TCD1, TCE0, TCE1, TCF0 and TCF1
QD
Enables or disables the quadrature decoder. Will only work on QD0,QD2 and QD4.
QDI
Enables or disables the quadrature decode index. Will only work on QDI0, QDI2 and QDI4.
QDIRM
Quadrature decode index recognition mode. This is a numeric constant between 0 and 3. Each value represents the 2 possible bit values for the two input signals. Will only work on QDIRM0, QDIRM2 and QDIRM4.
DIGFLT
Defines the length of digital filtering used. Events will be passed through to the event channel only when the event source has been active and sampled with the same level for a number of peripheral clock for the number of cycles as defined by DIGFLT.
The number of samples is in the range from 1-8. The default is 1 sample.
ATXMEGA
Example 1
' Select PortC.0 as INPUT to event channel 0
' Digflt0 = 8 --> Enable Digital Filtering for Event Channel 0. The Event must be active for 8 samples in order to be passed to the Event system
' Event Channel 1 INPUT = Timer/Counter C0 Overflow
' Event Channel 2 INPUT = Analog Input Port A Channel 0
' Event Channel 3 INPUT = Real Timer overflow
Config Event_system = Dummy , _
Mux0 = Portc.0 , Digflt0 = 8 , _
Mux1 = Tcc0_ovf , _
Mux2 = Adca_ch0 , _
Mux3 = Rtc_ovf
Example 2
'Event Channel 7 is input for the Timer/Counter TcD1 overflow
Config Event_system = Dummy , Mux7 = Tcd1_ovf
Example 3
' Using the Counter/Timer to count events like a falling edge on Pine.5
$regfile = "xm256a3bdef.dat"
$crystal = 32000000 '32MHz
$hwstack = 64
$swstack = 40
$framesize = 40
'configure the systemclock
Config Com7 = 57600 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8 'Portf.2 and Portf.3 is COM7
Open "COM7:" For Binary As #1
'Config Interrupts
Config Priority = Static , Vector = Application , Lo = Enabled , Med = Enabled 'Enable Lo Level Interrupts
Dim Timer_overflow As Bit
Print #1 , "---Event Counting with Timer C0 over Event Channel 0 from PINE.5----"
Config Porte.5 = Input
Config Xpin = Porte.5 , Outpull = Pullup , Sense = Falling 'enable Pullup and reaction on falling edge
Config Event_system = Dummy , Mux0 = Porte.5 , Digflt0 = 8 'Eventchannel 0 = PINE.5, enable digital filtering
Config Tcc0 = Normal , Prescale = E0 , Event_source = E0 , Event_action = Capture ' Normal = no waveform generation, Event Source = Event Channel 0
On Tcc0_ovf Timerd0_int
Enable Tcc0_ovf , Lo 'Enable overflow interrupt in LOW Priority
Tcc0_per = 5 'Interrupt when Count > 5
'################MAINLOOP#######################################################
Wait 1
Print #1 , "TCC0_CNT = " ; Tcc0_cnt 'Actual Count
If Timer_overflow = 1 Then
 Reset Timer_overflow
 Print #1 , "TCC0_OVERVLOW" 'Print it when Overflow Interrupt is fired
Timerd0_int:
Set Timer_overflow
