CONFIG OSC
Select and enable the oscillators available to the Xmega
See also ATXMEGA
CONFIG OSC=ENABLED|DISABLED , PLLOSC=ENABLED|DISABLED,  EXTOSC=ENABLED|DISABLED, 32KHZOSC=ENABLED|DISABLED,  32MHZOSC=ENABLED|DISABLED,  RANGE=range, 32KHZPOWERMODE=powermode, XOSC_SEL__STARTUP=xosc_sel_startup , PLLSOURCE=pll , PLLDIV2=plldiv , PLLMUL=pllmul , 32MHZCALIB= 32mhzcalib , 2MHZCALIB= 2mhzcalib , 2MHZDFL= 2MHZDFL , 32MHZDFL= 32MHZDFL
OSC
Use ENABLED to enable the internal 2 MHZ oscillator. This oscillator is enabled by default. Use DISABLED to disable the internal oscillator.
PLLOSC
Use ENABLED to enable the PLL oscillator. The oscillator is disabled by default.
EXTOSC
Use ENABLED to enable the external oscillator. The external oscillator is disabled by default.
32KHZOSC
Use ENABLED to enable the internal 32 KHz oscillator. This oscillator is disabled by default.
32MHZOSC
Use ENABLED to enable the internal 32 MHz oscillator. This oscillator is disabled by default.
RANGE
Specify the range of the external oscillator.
- 400KHZ_2MHZ
- 2MHZ_9MHZ
- 9MHZ_12MHZ
- 12MHZ_16MHZ
This option is only needed when using the external oscillator.
32KHZPOWERMODE
Select the power mode of the 32 KHz interal oscillator. This can be NORMAL or LOW_POWER.
The default is NORMAL
XOSC_SEL_STARTUP
The type and startup type of the crystal or resonator can be specified. Use a value of  :
- EXTCLK (6 CLK) , will select external clock
- 32KHZ (for 16 CLK) , will select 32.768 TOSC
- XTAL_256CLK  (for 256 CLK), will select 0.4-16 MHz XTAL
- XTAL_1KCLK  (for 1K CLK) , will select 0.4-16 MHz XTAL
- XTAL_16CLK   (for 16K CLK) , will select 0.4-16 MHz XTAL
PLLSOURCE
This option let you select the oscillator source of the PLL oscillator. Valid options are :
- RC2MHZ , the internal 2 MHz oscillator (default)
- RC32MHZ , the internal 32 MHz oscillator
- EXTCLOCK , an external clock signal or oscillator
PLLDIV2
This option let you select the PLL two divider. Valid options are ENABLED and DISABLED
PLLMUL
This option let you specify the PLL multiplication factor. The numeric value must be in the range from 1-31. A value of 0 disables the multiplication.
32MHZCALIB
This option allow you to specify the calibration source for the 32MHZ oscillator. The possible options are :
- RC32K  , selects the 32.768 KHZ internal oscillator
- XOSC32, selects the 32.768 KHz crystal oscillator on TOSC
- USBSOF , selects USB start of frame
2MHZCALIB
This option allow you to specify the calibration source for the internal 2MHZ oscillator. The possible options are :
- 32KHZINT  , selects the 32.768 KHZ internal oscillator. (default)
- 32KHZ_EXT_TOSC, selects the 32.768 KHz crystal oscillator on TOSC
32MHZDFL
This option will enable or disable the DFLL and auto calibration of the 32 MHZ oscillator.
Possible values :
- ENABLED
- DISABLED
2MHZDFL
This option will enable or disable the DFLL and auto calibration of the 2 MHZ oscillator.
Possible values :
- ENABLED
- DISABLED
You can also use automatic calibration. This will calibrate the 32 MHz oscillator using the 32 KHz oscillator.
The required code :
Config Osc = (enabled or disabled), 32mhzosc = Enabled , 32khzosc = enabled
OSC_DFLLCTRL.0 = 1    'enable
DFLLRC32M_CTRL.0 = 1 'enable
CONFIG SYSCLOCK
Config Osc = Enabled , 32mhzosc = Enabled ' enable 2 MHz and 32 MHz interal oscillators
PLL Example
'Clock: 32 MHz External 4 MHz Xtal, PLL x 8
Config osc = enabled , EXTOSC = enabled , pllosc = enabled , _
range = 2MHZ_9MHZ , startup = XTAL_16KCLK , pllsource = extclock , pllmul = 8
