CONFIG XPIN
Configures additional features of a processor port or pin.
CONFIG XPIN=PORT|PIN, OUTPULL=pull
Syntax Xmega
CONFIG XPIN=PORT|PIN, INVERTIO=invio, SLEWRATE=slew, OUTPULL=pull, SENSE=sense
Normal AVR port pins can be configured as an input or output. When configured as an input (CONFIG PIN=INPUT) they can also be set to tri-state (write a 0 to the PORT register) or to activate the pull up resistor(write a 1 to the PORT register).
Some new AVR processors use a special PUD register to control the pull up. The CONFIG XPIN automatically uses the proper registers to control the pull up state.
Normal AVR
PORT
PIN
The pin to be configured. For example PORTC.0
When configuring the whole port (all the pins must have the same functionality), use PORT. For example : PORTD
OUTPULL
Sets the output or pull mode. The following options are available:
- OFF :no pull up
- PULLUP : input pull up
Normal AVR processors (tiny,mega) have only one option : OUTPULL.
The compiler will either write a 1 or 0 to the PORT register or the PUEx register.
You can control a single pin using a port pin name like PORTB.0 or the whole register like PORTB.
Normal AVR code that use : PORTX.Y=1  to activate the pull up, should be written as : CONFIG XPIN=PORTX.Y,OUTPULL=PULLUP
XMEGA
You still need to use PORTx = state or PINx.y = state to configure the data direction of that port or pin in addition to CONFIG XPIN.
The xmega has many more options. The Xmega manual explains all the options.
The CONFIG XPIN statement will set the proper registers.
PORT
PIN
INVERTIO
This option will invert the data for both input and output modes.
Possible values : ENABLED (will invert data), DISABLED(normal mode)
SLEWRATE
Will enable or disable the slewrate. Enabling the slew rate will increase the rise/fall time by 50%-150%. Possible values : ENABLED, DISABLED
OUTPULL
- TOTEM : output totem pole
- BUSKEEPER : output totem pole, input bus keeper
- PULLDOWN : output totem pole, input pull down
- PULLUP : output totem pole, input pull up
- WIREDOR : output wired OR
- WIREDAND: output wired AND
-WIREDORPULL : output wired OR, input pull down
-WIREDANDPULL : output wired AND, input pull up
SENSE
In input mode, the trigger sense can be configured. Possible values :
- BOTH : sense both edges
- RISING : sense rising edge
-FALLING : sense falling edge
-LOW_LEVEL  :sense low level
- INP_DISABLED : digital input buffer disabled (only PORTA-PORTF)
CONFIG PIN, CONFIG INT
Config Porte.5 = Input
Config Xpin = Porte.5 , Outpull = Pullup , Sense = Falling 'enable Pull up and reaction on falling edge
$regfile = "xm256a3budef.dat"
$Crystal = 32000000 '32MHz
Config Xpin = Portc.0 , Slewrate = Enabled , Outpull = Buskeeper , Sense = Low_level
Config Xpin = Portc.1 , Slewrate = Enabled , Outpull = Buskeeper , Sense = Low_level
'setup the whole port at once
Config Xpin = Portd , Slewrate = Enabled , Outpull = Buskeeper , Sense = Low_level
