RB FILLCOLORS
Fills the entire memory of the active channel with a specified color
RB_FILLCOLORS Color
Color
Color is a byte array or variable that contains color information.
The entire memory of the active channel is filled with the specified color.
This statement will not update the LED's. This means that you need to use RB_SEND to update the LED's. Or use RB_FILL which will update the LED's as well.
RB_ADDCOLOR , RB_ANDCOLOR , RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL , RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT , RB_ROTATERIGHT , RB_SHIFTLEFT , RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR
' rainbow_ws2812_Levelmeter.bas
' This example demonstrate the switching between two Rainbow-Stripes while simulating
' a simple kind of an stereo levelmeter and the use of some RB_statements.
$Regfile = "m88pdef.dat"
$Crystal=8000000
$hwstack=40
$swstack=16
$framesize=32
Config RAINBOW= 2, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0 , RB1_LEN=8, RB1_PORT=PORTB,rb1_pin=1
Dim n as Byte
Dim Color as DWord
Dim CH as Byte
Dim LEFT_Level as Byte , Left_Level_OLD as Byte
Dim Right_Level as Byte , Right_Level_OLD as Byte
Const Channels = 2
Const Backcolor = &H000005
'----[MAIN]---------------------------------------------------------------------
Color = Backcolor
For ch = 0 to Channels -1
 Rb_SelectChannel Ch
 RB_Fillcolors Color
 Rb_SetTableColor 0,0
 RB_send
 incr n: n = n and &H30 'n counts from 0 to 63
 If n = 0 then Gosub Get_Level 'Read signal
 'Switch channel
 toggle Ch
 Rb_SelectChannel Ch
 Waitms 40
 If ch = 0 then 'Channel 0
 If left_level_old < left_level then
 incr Left_level_old
 ElseIf Left_level_old > Left_level then
 Decr Left_level_old
 End if
 RB_Fillcolors Color
 Rb_SetTableColor Left_level_old ,0
 Else 'Channel 1
 If right_level_old < right_level then
 incr right_level_old
 ElseIf right_level_old > right_level then
 Decr right_level_old
 End if
 RB_Fillcolors Color
 Rb_SetTableColor right_level_old ,0
 end if
 RB_Send
Get_Level:
 Left_Level = rnd(7)
 Right_Level = rnd(7)
Rainbow_Colors:
 Data 100,50,0 'orange
Languages   English
