RB CHANGEPIN
Changes the defined output pin at run time
RB_CHANGEPIN Port , Pin
Port |
A numeric variable or constant with the I/O address of the port. Notice that this is an absolute memory address. For ports in the normal IO range, you need to add a value of &H20 to the address.
Example : Const nprt=varptr(portb) + &H20 Rb_ChangePIN nprt, 1 |
Led |
A numeric variable or constant with the pin number in the range from 0-7 |
When you want to use multiple stripes with the same color, it would require CONFIG RAINBOW to set up all these stripes.
But each configured pin will use memory for the RGB information. When you change the pin at run time, you will use the color information of one stripe.
RB_ADDCOLOR , RB_ANDCOLOR , RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL , RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT , RB_ROTATERIGHT , RB_SHIFTLEFT , RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR
'------------------------------------------------------------------------------- ' rainbow_ws2812_Demo.bas '------------------------------------------------------------------------------- $Regfile = "m88pdef.dat" $Crystal = 8000000 $hwstack = 40 $swstack = 16 $framesize = 32 Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0 ' ^ connected to pin 0 ' ^------------ connected to portB ' ^-------------------------- 8 leds on stripe ' ^------------------------------------- 1 channel 'Global Color-variables Dim Color(3) as Byte R alias Color(_base) : G alias Color(_base + 1) : B alias Color(_base + 2) 'CONST const numLeds=8 '----[MAIN]--------------------------------------------------------------------- Dim n as Byte, state as Byte, tel as Byte state=0 : tel=0 RB_SelectChannel 0 ' select first channel R = 50 : G = 0 : B = 100 ' define a color RB_SetColor 0 , color(1) ' update led on the left RB_SetColor 7 , color(1) ' update led on the right RB_Send Do For n = 1 to Numleds/2 - 1 rb_Shiftright 0 , Numleds/2 'shift to the right rb_Shiftleft 4 , Numleds/2 'shift to the left all leds except the last one Waitms 100 RB_Send Next For n = 1 to Numleds/2 - 1 rb_Shiftleft 0 , Numleds/2 'shift to the left all leds except the last one rb_Shiftright 4 , Numleds/2 'shift to the right Waitms 100 RB_Send Next 'waitms 500 'wait a bit select case state case 0 : r=r+5 : Rb_AddColor 0, color(1) : rb_send: tel=tel+1 case 1: g=g+5 : Rb_subColor 0, color(1) : rb_send:tel=tel+1 case 2: b=b+5 : Rb_orColor 0, color(1) : rb_send: tel=tel+1 case 3: Rb_ClearStripe : tel=4 case 4: rb_send : tel=5 case 5: Rb_Fill color(1) : tel=5 case 6: const nprt=varptr(portb) + &H20 : Rb_ChangePIN nprt, 1 case else state=0 end select if tel>=2 then state=state+1 : tel=0 end if Loop
| Languages | English |
