RB ANDCOLOR
Ands specified color info to the specified LED in memory
RB_ANDCOLOR Led , Color
Color |
Color is a byte array or variable that contains color information. |
Led |
The index of the LED number. First LED is 0. |
The operation is performed on the memory. An AND operation can clear part of a color. You need to use RB_SEND so that the LED reflects the new color information.
RB_ADDCOLOR , RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL , RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT , RB_ROTATERIGHT , RB_SHIFTLEFT , RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR
'------------------------------------------------------------------------------- ' rainbow_ws2812_Demo_Softblink.bas 'This demo show RB_OrColor and RB_AndColor which can be used 'for a flashing LED with a fade effect. '------------------------------------------------------------------------------- $Regfile = "m88pdef.dat" $Crystal=8000000 $hwstack=32 $swstack=16 $framesize=32 Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0 ' ^ connected to pin 0 ' ^------------ connected to portB ' ^-------------------------- 8 leds on stripe ' ^------------------------------------- 1 channel Const Numled=8 Dim MASK as Dword Dim Fade as Byte '----[MAIN]--------------------------------------------------------------------- RB_SelectChannel 0 ' select first channel Do For Fade = 0 to 7 Waitms 20 Shift MASK , left Incr MASK RB_ORColor 0 , MASK RB_Send Next For Fade = 0 to 7 Waitms 20 Shift MASK , right RB_ANDColor 0 , MASK RB_Send Next Loop
| Languages | English |
