What is new
- tiny461 and tiny861 only did set pcie0 when you enable the PCINT because there is just one interrupt in the chip. In 2080, both PCIE0 and PCIE1 are enabled/disabled.
- added m48PB, m88PB, 168PB and m328PB dat files.
- new Rainbow functions : RB_Color and RB_Copy added by Galahat
- simulator did not show maximum values of DWORD correct.
- RB GETCOLOR and RB LOOKUPCOLOR functions did return false result when index was a variable.
- some font problems solved.
- simulator could crash for xmega processors.
- when using non-mono font like Arial, text selection does not work properly. Use a font like CONSOLAS.
- Added option 'Use Monofont' for backwards compatibility
- Some new atmel PDF files could not be loaded with the PDF viewer. Viewer is rewritten and requires a new DLL named BASPDF.DLL
- getadc() on m640.m1280/m2560 or any other processor with 6 mux bits did not set mux5 bit for getadc(32) and higher.
- generic byte compare() function added, based on code and idea from MWS. (Magic White Smoke)
- varexist() did not support ALIAS.
- XMega64A1-SRAM 4-Port-Sample.bas sample added for setup EBI 4 port on XMega. See also Adding XRAM to XMEGA using EBI
- when bascom-avr.xml options file exists in the bascom application folder, that option file will be used.
- format is extended to use a variable for the mask.
- config xpin did not support alias for the pin.
- bufspace() did not support UART 5-8
- INSERTCHAR and DELCHAR use Z pointer which must be cleared for XMEGA. fixed in mcs.lib
- programmer did not fetch correct chip from editor when code was not saved. this would give a chip mismatch.
- assigning a negative value to a dword did not throw an error.
- code explorer can show estimated stack usage.
- higher standard baud rates added to terminal emulator
- added support for EDMA in xmega8/16/32 E5. See config EDMA
- version() function did not append to string but would overwrite existing string data.
- right() adds an additional null byte when a numeric constant is used for the number of characters to copy.
- new dim option to specify multiple items : dim a,b,c,d as byte failed when using multiple indexed items.
- all dat files updated with CONFIG information.
- printing values from multi index variables failed : print index(index1,index2)
-  m1284pdef.dat updated with missing TIFR3 register.
- more fonts in various sizes from Adam Siwek.
- power() function for doubles did not work correct when assigned to a function
- some new atmel PDF files can not be loaded with the PDF viewer. Viewer is rewritten.
- SSD1306 i2c oled driver updated for Xmega.
- m649A and m649P dat files added.
- LCDFONT prm, added. prm selects the font table (0-3) of a text LCD.
- CONFIG POWER_REDUCTION set register to 0 in some conditions. Also added LCD and other new Xmega power reduction options.
- CONFIG OSC extended with calibration register settings and DFLL.
- val() for doubles has a bug for XMega >64KB chips
- added flip(byte) function to mirror bits in a byte
- xmega128B3 dat file added
- readsig also works for normal AVR processors.
- inputbin and printbin load 1 element too many with arrays using base 0.
- config inputbin added to allow reading packets of up to 64 KB
- added support for LCD text OLED RS0010 lcd4_anypin_oled_RS0010.lib
- FT81x support added
- M324PB dat file added.
- I2CINIT enhanced for multiple TWI
- I2C TWI-MULTI.lib added to support multiple TWI busses.
- second SPI on m328PB added : INIT1SPI, SPI1OUT, SPI1MOVE, SPI1IN
-  user donated library I2C DOGS104 driver, SSD1803A included.
- URL2IP(url) function added to W5100 to do DNS lookup using google DNS server
- when defining a const Updateeprom , the eeprom will be updated. which means that the value will only be written when it differs
- BASE64ENC and BASE64DEC can work on byte arrays too.
2017, 2080 release
- SGN extended to byte, integer, word, dword and long
