CONFIG PRINTBIN
Configure PRINTBIN behavior
CONFIG PRINTBIN = extended
extended
This mode is the only mode. It allows to send packets greater than 255 bytes.
The maximum packet size is 64 KB.
Because support for big packets requires more code, it is made optional.
You can not change between normal and extended mode dynamically. If you chose to use extended mode, this will be used for all your PRINTBIN code.
CONFIG PRINT
Config Printbin = Extended
Dim A(1000)
Printbin A(1) ; 1000
