CONFIG KBD
Configure the GETKBD() function and tell which port to use.
CONFIG KBD = PORTx , DEBOUNCE = value [, DELAY = value] [,COLS=cols]
PORTx |
The name of the PORT to use such as PORTB or PORTD. |
DEBOUNCE |
By default the debounce value is 20. A higher value might be needed. The maximum is 255. |
Delay |
An optional parameter that will cause Getkbd() to wait the specified amount of time after the key is detected. This parameter might be added when you call GetKbd() repeatedly in a loop. Because of noise and static electricity, wrong values can be returned. A delay of say 100 mS, can eliminate this problem. |
COLS |
This value is 4 by default. Some chips do not have port pin 7 and for these cases you can use COLS=3, or COLS=2. This does assume that columns are connected to the high port nibble. |
The GETKBD() function can be used to read the pressed key from a matrix keypad attached to a port of the uP.
You can define the port with the CONFIG KBD statement.
In addition to the default behavior you can configure the keyboard to have 6 rows instead of 4 rows.
CONFIG KBD = PORTx , DEBOUNCE = value , rows=6, row5=pinD.6, row6=pind.7
This would specify that row5 is connected to pind.6 and row7 to pind.7
Note that you can only use rows=6. Other values will not work.
'----------------------------------------------------------------------------------------- 'name : getkbd.bas 'copyright : (c) 1995-2005, MCS Electronics 'purpose : demo : GETKBD 'micro : Mega48 'suited for demo : yes 'commercial addon needed : no '----------------------------------------------------------------------------------------- $regfile = "m48def.dat" ' specify the used micro $crystal = 4000000 ' used crystal frequency $baud = 19200 ' use baud rate $hwstack = 32 ' default use 32 for the hardware stack $swstack = 10 ' default use 10 for the SW stack $framesize = 40 ' default use 40 for the frame space 'specify which port must be used 'all 8 pins of the port are used Config Kbd = Portb 'dimension a variable that receives the value of the pressed key Dim B As Byte 'loop for ever Do B = Getkbd() 'look in the help file on how to connect the matrix keyboard 'when you simulate the getkbd() it is important that you press/click the keyboard button ' before running the getkbd() line !!! Print B 'when no key is pressed 16 will be returned 'use the Lookup() function to translate the value to another one ' this because the returned value does not match the number on the keyboad Loop End
