Using the 1 WIRE protocol
The 1-wire protocol was invented by Dallas Semiconductors and needs only 1 wire for two-way communication. You also need power and ground of course.
This topic is written by Göte Haluza. He tested the new 1-wire search routines and is building a weather station.
Dallas Semiconductor (DS) 1-wire. This is a brief description of DS 1-wire bus when used in combination with BASCOM. For more detailed explanations about the 1-wire bus, please go to [1]. Using BASCOM makes the world a lot easier. This paper will approach the subject from a "BASCOM-user-point-of-view".
1-wire-net is a serial communication protocol, used by DS devices. The bus could be implemented in two basic ways :
With 2 wires, then DQ and ground is used on the device. Power is supplied on the DQ line, which is +5V, and used to charge a capacitor in the DS device. This power is used by the device for its internal needs during communication, which makes DQ go low for short periods of time. This bus is called the 1-wire bus.
With 3 wires, when +5V is supplied to the VDD line of the device, and DQ + ground as above. This bus is called the 2-wire bus.
So, the ground line is "not counted" by DS. But hereafter we use DS naming conventions.
How it works. (1-wire)
The normal state of the bus is DQ=high. Through DQ the device gets its power, and performs the tasks it is designed for.
When the host (your micro controller (uC)) wants something to happen with the 1-wire bus, it issues a reset-command. That is a very simple electric function that happens then; the DQ goes active low for a time (480uS on original DS 1-wire bus). This put the DS-devices in reset mode; then (they) send a presence pulse, and then (they) listen to the host.
The presence pulse is simply an active low, this time issued by the device(s).
Now, the host cannot know what is on the bus, it is only aware of that at least 1 DS device is attached on the bus.
All communication on the 1-wire bus is initialized by the host, and issued by time-slots of active-low on a normally high line (DQ), issued by the device, which is sending at the moment. The devices(s) internal capacitor supplies its power needs during the low-time.
How do you work with 1-wire-bus
Cable lengths
Noise and CRC
Transfer speed
Topology
The benefit of the 1-wire bus
The disadvantages of the 1-wire bus
So far as I know, DS is the only manufacturer of sensors for the bus. Some people think their devices are expensive. And, until now, it was really difficult to communicate with the devices. Particularly when using the benefit of several devices on one bus. Still some people say that the 1w-bus is slow - but I don't think so.
Göte Haluza
System engineer
