Program Show Result
Use this option to view information concerning the result of the compilation.
See the Options Compiler Output for specifying which files will be created.
The files that can be viewed are "report" and "error".
File show result shortcut : Basc0036 wmf.gif ,CTRL+W
Information provided in the report:
Info
Description
Report
Name of the program
Date and time
The compilation date and time.
Compiler
The version of the compiler.
Processor
The selected target processor.
SRAM
Size of microprocessor SRAM (internal RAM).
EEPROM
Size of microprocessor EEPROM (internal EEPROM).
ROMSIZE
Size of the microprocessor FLASH ROM.
ROMIMAGE
Size of the compiled program.
BAUD
Selected baud rate.
XTAL
Selected XTAL or frequency.
BAUD error
The error percentage of the baud rate.
XRAM
Size of external RAM if available.
Stack start
The location in memory, where the hardware stack points to. The HW-stack pointer grows downward.
S-Stacksize
The size of the software stack.
S-Stackstart
The location in memory where the software stack pointer points to. The software stack pointer grows downward.
Framesize
The size of the frame. The frame is used for storing local variables.
Framestart
The location in memory where the frame starts.
LCD address
The address that must be placed on the bus to enable the LCD display E-line.
LCD RS
The address that must be placed on the bus to enable the LCD RS-line
LCD mode
The mode the LCD display is used with. 4 bit mode or 8 bit mode.
LCD DB7-DB4
The port pins used for controlling the LCD in pin mode.
LCD E
The port pin used to control the LCD enable line.
LCD RS
The port pin used to control the LCD RS line.
Variable
The variable name and address in memory
Constant
Constants name and value
Some internal constants are :
_CHIP : number that identifies the selected chip
_RAMSIZE : size of SRAM
_ERAMSIZE : size of EEPROM
_XTAL : value of crystal
_BUILD : number that identifies the version of the compiler
_COMPILER : number that identifies the platform of the compiler
Warnings
This is a list with variables that are dimensioned but not used.
Some of them
EEPROM binary image map
This is a list of all ERAM variables with their value. It is only shown when DATA lines are used to create the EEP file. (EEPROM binary image).
When the option : Load Report in IDE, is set, the report will be shown as a text file in the IDE.
