Language Fundamentals
Characters from the BASCOM character set are put together to form labels, keywords, variables and operators.
These in turn are combined to form the statements that make up a program.
This chapter describes the character set and the format of BASCOM program lines. In particular, it discusses:
• The specific characters in the character set and the special meanings of some characters.
• The format of a line in a BASCOM program.
• Line labels.
• Program line length.
Character Set
The BASCOM numeric characters are the digits 0-9.
The letters A-H can be used as parts of hexadecimal numbers.
The following characters have special meanings in BASCOM statements and expressions:
Character
Name
ENTER
Terminates input of a line
Blank ( or space)
Single quotation mark (apostrophe)
Asterisks (multiplication symbol)
Plus sign
Comma
Minus sign
Period (decimal point)
Slash (division symbol) will be handled as \
Colon
Double quotation mark
Semicolon
Less than
Equal sign (assignment symbol or relational operator)
Greater than
Backslash (integer/word division symbol)
Exponent
The BASCOM program line
BASCOM program lines have the following syntax:
[[line-identifier]] [[statement]] [[:statement]] ... [[comment]]
Using Line Identifiers
BASCOM support one type of line-identifier; alphanumeric line labels:
An alphabetic line label may be any combination of from 1 to 32 letters and digits, starting with a letter and ending with a colon.
BASCOM keywords are not permitted.
The following are valid alphanumeric line labels:
Alpha:
ScreenSUB:
Test3A:
Case is not significant. The following line labels are equivalent:
alpha:
Alpha:
ALPHA:
Line labels may begin in any column, as long as they are the first characters other than blanks on the line.
Blanks are not allowed between an alphabetic label and the colon following it.
A line can have only one label. When there is a label on the line, no other identifiers may be used on the same line. So the label is the sole identifier on a line.
BASCOM Statements
• REM or (starts a comment)
• DIM
BASCOM LineLength
Comment
Comment is intended to clarify your code. Describe what the code is supposed to do.
You can use single line comment using the REM statement. By default, comment is shown in green.
Since REM is a lot of type work, you can also use the ' sign
When you want to comment multiple lines, you can also use block comment.
Block comment starts with '(
It ends with ')
Please notice that block comment must be the first non white space on the line.
Rem some comment
Print                                                      'also comment
'( block
comment
multiple lines
')print"ok"
Data Types
Elementary Data Types
• Bit (1/8 byte). A bit can hold only the value 0 or 1. A group of 8 bits is called a byte.
• Byte (1 byte).  Bytes are stores as unsigned 8-bit binary numbers ranging in value from 0 to 255.
• Integer (two bytes). Integers are stored as signed sixteen-bit binary numbers ranging in value from -32,768 to +32,767.
• Word (two bytes). Words are stored as unsigned sixteen-bit binary numbers ranging in value from 0 to 65535.
• Dword(fout bytes). Dwords are stored as unsigned 32-bit unsigned numbers ranging in value from 0 to 4294967295
• Long (four bytes). Longs are stored as signed 32-bit binary numbers ranging in value from -2147483648 to 2147483647.
• Single. Singles are stored as signed 32 bit binary numbers. Ranging in value from 1.5 x 10^–45 to 3.4 x 10^38
• Double. Doubles are stored as signed 64 bit binary numbers. Ranging in value from 5.0 x 10^–324 to 1.7 x 10^308
• String (up to 254 bytes). Strings are stored as bytes and are terminated with a 0-byte. A string dimensioned with a length of 10 bytes will occupy 11 bytes.
Variables
• A constant value:
A = 5
C = 1.1
• The value of another numeric variable:
abc = def
k = g
• The value obtained by combining other variables, constants, and operators: Temp = a + 5
Temp = C + 5
• The value obtained by calling a function:
Temp = Asc(S)
Constants
A constant is a placeholder for a fixed value : you can assign it with a value only once : CONST Something = 100
Constants can be assigned with a numeric or string value. To assign a string use double quotes :  CONST SomeString = "BASCOM"
You can also use expressions with constants : CONST SomeThing = 1 + 2 / (3+4)
When you keep the SHIFT key pressed and hover the mouse cursor over a constant, a tooltip/hint will show the value.
When using numeric constants in DATA lines, you need to inform the compiler about the data type. This is done by ending the constant value with a suffix. See the help for DATA.
Variable Names
AND = 8
ToAND = 8
(see BASCOM Reserved Words , for a complete list of reserved words).
Before assigning a variable, you must tell the compiler about it with the DIM statement.
You can also use DEFINT, DEFBIT, DEFBYTE ,DEFWORD ,DEFLNG or DEFSNG.
BITS and Interrupts
Bits are stored in bytes. A write to a bit/boolean variable is non-atomic. Which means that multiple operations are required to update the bit value in the byte. When interrupts are used that update bits in the same byte, you can have the effect that a change becomes lost.
To prevent this you can disable interrupts and enable them after you have updated the bit variable. Or you can use a byte instead which is recommended since it would use less code.
Expressions and Operators
• Arithmetic operators, used to perform calculations.
• Relational operators, used to compare numeric or string values.
• Logical operators, used to test conditions or manipulate individual bits.
• Functional operators, used to supplement simple operators.
1. Arithmetic
2. Relational
3. Logical
4. Functional
Arithmetic
• Integer
Example: Z = X \ Y
• Modulo Arithmetic
Modulo arithmetic provides the remainder, rather than the quotient, of   an integer division.
Example: X = 10 \ 4 : remainder = 10 MOD 4
• Overflow and division by zero
Relational Operators
Operator
Relation Tested
Expression
Equality
X = Y
Inequality
X <> Y
Less than
X < Y
Greater than
X > Y
Less than or equal to
X <= Y
Greater than or equal to
X >= Y
Logical Operators
There four operators in BASCOM are :
Operator
Meaning
NOT
Logical complement
AND
Conjunction
OR
Disjunction
XOR
Exclusive or
A = 63 And 19
PRINT A
A = 10 Or 9
PRINT A
Output
19
11
s exponent mantissa
Dim I as Integer, S as Single
S = 100.1 'assign the single
I = S  'will convert the single to an integer
500 + 30 + 2 + 2/10 + 5/100
_________
= 532.25
4 + 0 + 1 + 0 + 1/4
_________
= 5.25 Decimal
1 Decimal = 1 Binary
2 Decimal = 10 Binary
Floating-Point Complications
SUM = 0
FOR I% = 1 TO 10000
 SUM = SUM + 0.0001
NEXT I%
item1# = 69.82#
item2# = 69.20# + 0.62#
IEEE Details
Single-Precision Examples
1. Round-off error
.1235
-.1234
_____
.0001
3. Overflow and underflow
4. Quantizing error
Rounding
Double
Arrays
Dim A(10) As Byte
'create an integer
Dim C As Integer
'now fill the array
For C = 1 To 10
'assign array element
A(c)= C
' print it
Print A(c)
C = 0
A(c + 1)= 100
Print A(c + 1)
Strings
DIM S as STRING * 5
To assign the string:
Ds = "abcd"
s= "AB{027}cd"
Casting
Byte = LONG
Dim b as Byte
b = 123 ' ok this is normal
b = "A" ' b = 65
IF b = "A" then ' when b = 65
END IF
SINGLE CONVERSION
integer = single
single = long
