LCD4 anypin OLED RS0010
This LCD driver is intended to be used with the OLED LCD RS0010.
This LCD text driver can be used with any pin. It supports the WR pin in which case the LCD will be used in busy mode.
A typical sample is shown below.
$regfile = "m88def.dat" $crystal = 8000000 $baud = 19200 $hwstack=32 $swstack = 16 $framesize=24 $lib "lcd4_anypin_oled_RS0010.lib" 'override default lib with OLED lib 'Config Lcd Sets The Portpins Of The Lcd Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0 Config Lcd = 16x2 '16*2 type LCD screen Dim V As Byte Cls Lcd "ABC" ; Chr(253) Lowerline Lcd "test" Const Test = " this is a test" ' Just A Test Lcdfont 0 'select first font Cls Dim X As Byte , Y As Byte X = &B1000_0000 + 0 Lcdcmd &B0001_1111 'gmode Lcdcmd X 'X (0-99) Lcdcmd &B0100_0000 'Y (0-1) 'send data For V = 1 To 80 Lcddata &B10101010 Waitms 100 Next End
| Languages | English |
