I2C USI SLAVE
The I2C_USI_SLAVE library is a library that ships with the I2C slave add on package.
The purpose of the lib is to offer I2C/TWI slave support for processors that have an USI interface.
USI master support is bundled with the commercial version of Bascom. This library is named i2_USI.
The USI has two interrupts. One to detect the START condition and one to detect a counter overflow.
Unfortunately Atmel did not define an interrupt for STOP condition. This means that it is not possible to detect a STOP condition with an interrupt.
You can read the STOP condition bit from the USISR register but no interrupt will fire as for the START condition.
So in practice, the Twi_stop_received label will be called just before the I2CSTART is called or when data is clocked by the master.
The following example demonstrates how to receive multiple bytes. It emulates an I2c, EEPROM memory chip.
'------------------------------------------------------------------------------- ' (c) 2004-2015 MCS Electronics ' This demo demonstrates the USI I2C slave and emulates an EEPROM chip ' This is part of the I2C Slave library which is a commercial addon library ' Not all AVR chips have an USI !!!! '------------------------------------------------------------------------------- ' This is a simple sample. the master sends the address of the slave, the WORD address ' of the memory location, and a byte to store or read '------------------------------------------------------------------------------ ' The matching master code to write ' i2cstart : i2cwbyte &H40 : i2cwbyte low(address) : i2cwbyte high(address) : i2cwbyte value : i2cstop ' The mathing master code to read ' i2cstart : i2cwbyte &H40 : i2cwbyte low(address) : i2cwbyte high(address) : i2crepstart : i2cwbyte &H41 : i2cRbyte value, nack : i2cstop 'See also the eeprom_master.bas $regfile = "attiny2313.dat" '$regfile = "attiny85.dat" $crystal = 8000000 $hwstack = 44 $swstack = 16 $framesize = 28 config CLOCKDIV=1 'I2C pins on tiny2313 connected like : 'PB5 SDA 'PB7 SCL 'I2C pins on tiny85 connected like : 'PB0 SDA 'PB2 SCL config BASE=0 'arrays start at address 0 Const Cprint = 0 'make 0 for chips that have NO UART, make 1 when the micro has a UART and you want to show data on the terminal #if cPrint Config Com1 = 19200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0 print "USI DEMO" #endif config usi = twislave , address = &H40 'bascom uses 8 bit i2c address (7 bit shifted to the left with one bit) dim epr(128) as Eram byte 'for easy access to the memory dim wAdres as Word, bValue as Byte dim bAdresL as Byte at Wadres overlay 'overlay with wAdres LSB dim bAdresH as Byte at Wadres+1 overlay 'overlay with wAdres MSB 'do not forget to enable global interrupts since USI is used in interrupt mode enable interrupts 'it is important you enable interrupts do ! nop ; nothing to do here loop 'The following labels are called from the library. You need to insert code in these subroutines 'Notice that the PRINT commands are remarked. 'You can unmark them and see what happens, but it will increase code size 'The idea is that you write your code in the called labels. And this code must execute in as little time 'as possible. So when you slave must read the A/D converter, you can best do it in the main program 'then the data is available when the master requires it, and you do not need to do the conversion which cost time. 'A master can send or receive bytes. 'A master protocol can also send some bytes, then receive some bytes 'The master and slave address must match. 'the following labels are called from the library when master send stop or start Twi_start_received: #if cprint Print "Master sent start or repeated start" #endif Return Twi_stop_received: #if cprint Print "Master sent stop" #endif Return 'master sent our slave address and will now send data Twi_addressed_goread: #if cprint Print "We were addressed and master will send data" #endif Return Twi_addressed_gowrite: #if cprint Print "We were addressed and master will read data" #endif Return 'this label is called when the master sends data and the slave has received the byte 'the variable TWI holds the received value Twi_gotdata: #if cprint Print "received : " ; Twi ; " byte no : " ; Twi_btw ; "-"; usidr #endif Select Case Twi_btw Case 1 : bAdresL=TWI 'first byte is LSB Case 2 : bAdresH=TWI 'second byte is MSB case 3 : #if cprint print "address:" ; wAdres #endif epr(wAdres)=twi 'write to eeprom in case we receive a third byte which should only happen when we write to the slave End Select 'if you want to auto inc wAdres, use this code instead: ' Select Case Twi_btw ' Case 1 : bAdresL=TWI 'first byte is LSB ' Case 2 : bAdresH=TWI 'second byte is MSB ' case else : epr(wAdres)=twi 'write to eeprom in case we receive a third byte which should only happen when we write to the slave ' incr wAdres ' End Select Return 'this label is called when the master receives data and needs a byte 'the variable twi_btr is a byte variable that holds the index of the needed byte 'so when sending multiple bytes from an array, twi_btr can be used for the index Twi_master_needs_byte: #if cprint Print "Master needs byte : " ; Twi_btr print "address:" ; wAdres #endif twi=epr(wAdres) 'return the data from EEPROM 'when you want to support auto adres increase add this : 'incr wAdres Return
Master Example
'------------------------------------------------------------------------------ ' eeprom_master.bas ' demo for USI eeprom slave ' ' '------------------------------------------------------------------------------ $Regfile= "m88pdef.dat" $crystal=8000000 $HWstack=40 $SWstack=50 $FrameSize=40 $baud=19200 $lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI config CLOCKDIV=1 ' no need to change fuse byte, we set the divider to 1 Config Sda = Portc.4 ' I2C Bus konfigurieren Config Scl = Portc.5 Dim Address As Word Dim Value As Byte '!!!!!!!!!!!!!!!!!!!! 'osccal=46 'REMARK THIS LINE, THIS WAS REQUIRED for the test chip '!!!!!!!!!!!!!!!!!!!! Print "Start" I2cinit ' init i2c For Address = 0 To 10 ' just test a bit value=address+10 print "write "; address ; ":";value I2cstart : I2cwbyte &H40 'slave address I2cwbyte Low(address) 'LSB first I2cwbyte High(address) 'MSB I2cwbyte Value 'write value I2cstop Waitms 500 next print "Read" For Address = 0 To 10 ' The mathing master code to read I2cstart : I2cwbyte &H40 'send slave WRITE address I2cwbyte Low(address) : I2cwbyte High(address) : 'send eeprom address I2crepstart 'repeated start I2cwbyte &H41 'write slave READ address I2crbyte Value , Nack 'read eeprom value I2cstop print address;":";value Next Address ' increment address byte end 'EXPECTED OUTPUT '( Start write 0:10 write 1:11 write 2:12 write 3:13 write 4:14 write 5:15 write 6:16 write 7:17 write 8:18 write 9:19 write 10:20 Read 0:10 1:11 2:12 3:13 4:14 5:15 6:16 7:17 8:18 9:19 10:20 ')
| Languages | English |
