I2C USI
The I2C_USI library is an alternative I2C master library. It is intended to be used with processors that have an USI interface.
Using the hardware is better since it will use less processor resources.
If a processor has TWI, use the TWI
If a processors has USI, use the USI
If a processor has no hardware I2C, use the default built in software routines.
To use the USI in master mode, use CONFIG USI.
'------------------------------------------------------------------------------ ' (c) 1995-2014 MCS Electronics ' USI-MASTER.bas ' USI used as TWI master demo '------------------------------------------------------------------------------ $regfile = "attiny2313.dat" $crystal = 8000000 $hwstack = 40 $swstack = 16 $framesize = 24 $baud = 19200 config usi = twimaster , mode = fast dim b as byte i2cinit do i2cstart i2cwbyte &H40 'send slave WRITE address for PCF8574 i2cwbyte &B10101010 'send a pattern i2crepstart 'repeated start i2cwbyte &H41 'send slave READ address i2crbyte b , ack 'read a byte i2crbyte b , nack 'and again i2cstop 'end transaction and free bus waitms 100 'some delay not required only when you print loop
Languages | English |
