GLCDEADOGMXL240-7-I2C
This library was sponsored by a customer.
The library supports the EADOGMXL240-7 in I2C mode.
The library supports all the usual graphical LCD commands.
'------------------------------------------------------------------------------- ' eadogxl240-7.bas ' (c) MCS Electronics 1995-2015 ' Sample to demo the EADOGXL240-7 LCD in I2C mode ' '------------------------------------------------------------------------------- $regfile = "M328pdef.dat" ' the used chip $crystal = 8000000 ' frequency used $baud = 19200 ' baud rate $hwstack = 40 $swstack = 40 $framesize = 40 Config Scl = Portc.5 ' we need to provide the SCL pin name Config Sda = Portc.4 ' we need to provide the SDA pin name $lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI Config Twi = 400000 'speed 400 KHz I2cinit $lib "glcdEADOGMXL240-7-I2C.lib" 'override the default lib with this special one #if _build < 2078 Dim ___lcdrow As Byte , ___lcdcol As Byte #endif Config Graphlcd = Custom , Cols = 240 , Rows = 128 , Lcdname = "EADOGXL240-7" Cls Setfont Font8x8tt 'You can use locate but the columns have a range from 1-240 'When you want to show somthing on the LCD, use the LDAT command Lcdat 1 , 1 , "11111111" Lcdat 2 , 1 , "88888888" Lcdat 12 , 64 , "MCS Electronics" , 1 Showpic 60 , 0 , Plaatje Circle(30 , 30) , 20 , 255 Line(0 , 0) -(239 , 127) , 255 ' diagonal line Line(0 , 127) -(239 , 0) , 255 ' diagonal line End $include "font8x8TT.font" Plaatje: $bgf "ks108.bgf" 'include the picture data
| Languages | English |
