File Open
With this option you can load an existing program from disk.
BASCOM saves files in standard ASCII format. Therefore, if you want to load a file that was made with another editor be sure that it is saved as an ASCII file. Most programs allow you to export the file as a DOS or ASCII file.
Note that you can specify that BASCOM must reformat the file when it opens it with the Options Environment option. This should only be necessary when loading files made with another editor.
File open shortcut :
fileopen
 CTRL+O
