Error Codes
The following table lists errors that can occur.
Error
Description
1
Unknown statement
2
Unknown structure EXIT statement
3
WHILE expected
4
No more space for IRAM BIT
5
No more space for BIT
6
. expected in filename
7
IF THEN expected
8
BASIC source file not found
9
Maximum 128 aliases allowed
10
Unknown LCD type
11
INPUT, OUTPUT, 0 or 1 expected
12
Unknown CONFIG parameter
13
CONST already specified
14
Only IRAM bytes supported
15
Wrong data type
16
Unknown Definition
17
9 parameters expected
18
BIT only allowed with IRAM or SRAM
19
STRING length expected (DIM S AS STRING * 12 ,for example)
20
Unknown DATA TYPE
21
Out of IRAM space
22
Out of SRAM space
23
Out of XRAM space
24
Out of EPROM space
25
Variable already dimensioned
26
AS expected
27
parameter expected
28
IF THEN expected
29
SELECT CASE expected
30
BIT's are GLOBAL and can not be erased
31
Invalid data type
32
Variable not dimensioned
33
GLOBAL variable can not be ERASED
34
Invalid number of parameters
35
3 parameters expected
36
THEN expected
37
Invalid comparison operator
38
Operation not possible on BITS
39
FOR expected
40
Variable can not be used with RESET
41
Variable can not be used with SET
42
Numeric parameter expected
43
File not found
44
2 variables expected
45
DO expected
46
Assignment error
47
UNTIL expected
50
Value doesn't fit into INTEGER
51
Value doesn't fit into WORD
52
Value doesn't fit into LONG
60
Duplicate label
61
Label not found
62
SUB or FUNCTION expected first
63
Integer or Long expected for ABS()
64
, expected
65
device was not OPEN
66
device already OPENED
68
channel expected
70
BAUD rate not possible
71
Different parameter type passed then declared
72
Getclass error. This is an internal error.
73
Printing this FUNCTION not yet supported
74
80
Code does not fit into target chip
81
Use HEX(var) instead of PRINTHEX
82
Use HEX(var) instead of LCDHEX
85
Unknown interrupt source
86
Invalid parameter for TIMER configuration
87
ALIAS already used
88
0 or 1 expected
89
Out of range : must be 1-4
90
Address out of bounds
91
INPUT, OUTPUT, BINARY, or RANDOM expected
92
LEFT or RIGHT expected
93
94
Too many bits specified
95
Falling or rising expected for edge
96
Pre scale value must be 1,8,64,256 or 1024
97
SUB or FUNCTION must be DECLARED first
98
SET or RESET expected
99
TYPE expected
100
No array support for IRAM variables
101
Can't find HW-register
102
Error in internal routine
103
= expected
104
LoadReg error
105
StoreBit error
106
Unknown register
107
LoadnumValue error
108
Unknown directive in device file
109
= expected in include file for .EQU
110
Include file not found
111
SUB or FUNCTION not DECLARED
112
SUB/FUNCTION name expected
113
SUB/FUNCTION already DECLARED
114
LOCAL only allowed in SUB or FUNCTION
115
  1. channel expected
116
Invalid register file
117
Unknown interrupt
126
NEXT expected.
129
( or ) missing.
200
.DEF not found
201
Low Pointer register expected
202
.EQU not found, probably using functions that are not supported by the selected chip
203
Error in LD or LDD statement
204
Error in ST or STD statement
205
} expected
206
Library file not found
207
Library file already registered
210
Bit definition not found
211
External routine not found
212
LOW LEVEL, RISING or FALLING expected
213
String expected for assignment
214
Size of XRAM string 0
215
Unknown ASM mnemonic
216
CONST not defined
217
No arrays allowed with BIT/BOOLEAN data type
218
Register must be in range from R16-R31
219
INT0-INT3 are always low level triggered in the MEGA
220
Forward jump out of range
221
Backward jump out of range
222
Illegal character
223
  • expected
224
Index out of range
225
() may not be used with constants
226
Numeric of string constant expected
227
SRAM start greater than SRAM end
228
DATA line must be placed after the END statement
229
End Sub or End Function expected
230
You can not write to a PIN register
231
TO expected
232
Not supported for the selected micro
233
READ only works for normal DATA lines, not for EPROM data
234
') block comment expected first
235
'( block comment expected first
236
Value does not fit into byte
238
Variable is not dimensioned as an array
239
Invalid code sequence because of AVR hardware bug
240
END FUNCTION expected
241
END SUB expected
242
Source variable does not match the target variable
243
Bit index out of range for supplied data type
244
Do not use the Y pointer
245
No arrays supported with IRAM variable
246
No more room for .DEF definitions
247
. expected
248
BYVAL should be used in declaration
249
ISR already defined
250
GOSUB expected
251
Label must be named SECTIC
252
Integer or Word expected
253
ERAM variable can not be used
254
Variable expected
255
Z or Z+ expected
256
Single expected
257
"" expected
258
SRAM string expected
259
- not allowed for a byte
260
Value larger than string length
261
Array expected
262
ON or OFF expected
263
Array index out of range
264
Use ECHO OFF and ECHO ON instead
265
offset expected in LDD or STD like Z+1
266
TIMER0, TIMER1 or TIMER2 expected
267
Numeric constant expected
268
Param must be in range from 0-3
269
END SELECT expected
270
Address already occupied
322
Data type not supported with statement
323
Label too long
324
Chip not supported by I2C slave library
325
Pre-scale value must be 1,8,32,128,256 or 1024
326
  1. ENDIF expected
327
Maximum size is 255
328
Not valid for SW UART
329
FileDateTime can only be assigned to a variable
330
Maximum value for OUT is &H3F
332
$END ASM expected
334
') blockcomment end expected
335
Use before DIM statements
336
Could not set specified CLOCK value
337
No more space for labels
338
AS expected
339
Bytes to read may not be 0.
340
Variable is used as CONSTANT
341
OFFSET Error, contact MCS
342
OFFSET not allowed, too many locals used
343
Variable not supported with this function/statement
344
Program will overwrite bootloader
345
UART not available for the selected micro
346
External interrupt not supported or no settings found in DAT file
347
External interrupt mode not supported or found in DAT file
349
Setting not supported or not found in DAT file
350
Interrupt needs return
351
Not supported yet.
352
ALIAS can not be CONST or DIMMED variable
353
Reserved word may not be used
354
Previous Macro definition must be ended first
355
Macro previously defined
356
String constant size exceeded
357
Too many constants, increase resource languages
358
.DEF error, already defined
359
Operation not allowed on register
360
PRESCALE can not be used in COUNTER mode
361
Member expected
362
SBIC or SBIS was used followed by IN, OUT, SBIC, SBIS, SBI or CBI that also need to be converted.
363
No more room for EPROM DATA Index
364
Name not allowed, is used by constant/variable
365
Function not allowed in PRINT
366
Bit value out or range
367
Function name not allowed
368
Name used by label
369
Duplicate label name used by const or variable
370
Out of Flash memory
371
372
SE entry missing in DAT file
373
Re-Configuration not allowed
374
. not allowed.
375
Duplicate definition
376
Config not found
377
Unexpected non numeric characters found
378
CAN BAUD not possible
379
Syntax error
380
Array<>Non Array mismatch
381
CONFIG RC5 not found
382
variable does not match FOR
383
Register range must be within [R16-R23]
384
Register range must be within [R16-R31]
385
Register must be even within [R0-R30]
386
Register R0 expected
387
IO address must be in range [0-31]
388
Bit number must be in range [0-7]
389
Constant out of range [0-65535]
390
Float not allowed for index
391
JTAG can not be disabled
392
Invalid operator
393
UART is fixed
394
Unsupported data type for BYREG
395
Index out of range
396
Delay not possible with selected frequency. Use WAITMS
397
.ORG exceeds PC
398
Single or Double expected
999
DEMO/BETA only supports 4096 bytes of code
9999
Illegal version. Please remove this illegal crack.
You will not always get this message or error. When bascom finds traces of an illegal version it will generated random bugs in your code which are hard to find.
It can also show this error.
Only download software from the mcselec.com server.
Other error codes are internal ones. Please report them to support@ when you encounter them.
The Code explorer can give different errors. Here is a table with errors and how you can modify your code.
Config Lcd = 16 * 2
Config Lcd = 16X2
Change the * into an X
Cursor Off Noblink
Cursor Off , Noblink
Add a comma
