Edit Proper Indent
This option will properly indent your code.
Indention is used to make code better readable.
Every structure will be indented. And nested will increase indenting.
This code :
For C = 0 To 100
B = A(c)
Print "Read " ; C ; ":" ; B ; "/" ; Hex(b)
Waitms 4
Will be transformed into :
For C = 0 To 100
B = A(c)
Waitms 4
And this is a sample with nesting :
Input "Data to write ? (0-255)" , D
Print "Reading content of EEPROM (via ERAM Byte)"
For C = 0 To 100
B = A(c)
Waitms 4
When indenting does not work you need to check your code for mistakes. For example for endif instead of End If.
| Languages | English |
