Edit Insert ASCII
This option will show a pop up window from which you can select an ASCII character.
In BASCOM you can embed ASCII characters by using brackets embedded with the ASCII code like : {065}
For example : Dim S As String : S="AB{067}"
This is the same as S="AAA"
The pop up lists shows all ASCII values and when you click the OK-button, the brackets are added.
| Languages | English |
