EXTENDED I2C
Instruct the compiler to use parts of the extended i2c library
$LIB = "i2c_extended.lib"
The I2C library was written when the AVR architecture did not have extended registers. The designers of the AVR chips did not preserve enough space for registers. So when they made bigger chips with more ports they ran out of registers.
They solved it to use space from the RAM memory and move the RAM memory from &H60 to &H100.
In the free space from &60 to &H100 the new extended register were located.
While this is a practical solution, some ASM instructions could not be used anymore. This made it a problem to use the I2C statements on PORTF and PORTG of the Mega128.
The extended i2c library is intended to use I2C on portF and portG on the M64 and M128.
It uses a bit more space then the normal I2C lib.
Best would be that you use the TWI interface and the i2c_twi library as this uses less code. The disadvantage is that you need fixed pins as TWI used a fix pin for SCL and SDA.
'------------------------------------------------------------------------------- ' (c) 2005 MCS Electronics ' This demo shows an example of I2C on the M128 portF ' PORTF is an extened port and requires a special I2C driver '------------------------------------------------------------------------------- $regfile = "m128def.dat" ' the used chip $crystal = 8000000 $baud = 19200 ' baud rate $lib "i2c_extended.lib" Config Scl = Portf.0 ' we need to provide the SCL pin name Config Sda = Portf.1 ' we need to provide the SDA pin name Dim B1 As Byte , B2 As Byte Dim W As Word At B1 Overlay I2cinit ' we need to set the pins in the proper state Dim B As Byte , X As Byte Print "Mega128 master demo" Print "Scan start" For B = 1 To 254 Step 2 I2cstart I2cwbyte B If Err = 0 Then Print "Slave at : " ; B End If I2cstop Next Print "End Scan" Do I2cstart I2cwbyte &H70 ' slave address write I2cwbyte &B10101010 ' write command I2cwbyte 2 I2cstop Print Err I2cstart I2cwbyte &H71 I2crbyte B1 , Ack I2crbyte B2 , Nack I2cstop Print "Error : " ; Err ' show error Waitms 500 'wait a bit Loop End
