Changes compared to BASCOM-8051
The design goal was to make BASCOM-AVR compatible with BASCOM-8051.
For the AVR compiler some statements had to be removed.
New statements were also added. And some statements were changed.
They need specific attention, but the changes to the syntax will be made available to BASCOM-8051 too in the future.
Statements that were removed
STATEMENT
DESCRIPTION
$LARGE
Not needed anymore.
$ROMSTART
Code always starts at address 0 for the AVR. Added again in 1.11.6.2
$LCDHEX
Use LCD Hex(var) instead.
$NOINIT
Not needed anymore. Added in 1.11.6.2
$NOSP
Not needed anymore
$NOBREAK
Can't be used anymore because there is no object code that can be used for it.
$OBJ
Removed.
BREAK
PRIORITY
AVR does no allow setting priority of interrupts
PRINTHEX
You can use Print Hex(var) now
LCDHEX
You can use Lcd Hex(var) now
Statements that were added
STATEMENT
DESCRIPTION
FUNCTION
You can define your own user FUNCTIONS.
LOCAL
You can have LOCAL variables in SUB routines or FUNCTIONS.
New math statement. Var = 2 ^ 3 will return 2*2*2
SHIFT
Because ROTATE was changed, I added the SHIFT statement. SHIFT works just like ROTATE, but when shifted left, the LS BIT is cleared and the carry doesn't go to the LS BIT.
LTRIM
LTRIM, trims the leftmost spaces of a string.
RTRIM
RTRIM, trims the rightmost spaces of a string.
TRIM
TRIM, trims both the leftmost and rightmost spaces of a string.
Statements that behave differently
STATEMENT
DESCRIPTION
ROTATE
Rotate now behaves like the ASM rotate, this means that the carry will go to the most significant bit of a variable or the least significant bit of a variable.
CONST
String were added to the CONST statement. I also changed it to be compatible with QB.
DECLARE
BYVAL has been added since real subprograms are now supported.
DIM
You can now specify the location in memory of the variable.
Dim v as byte AT 100, will use memory location 100.
