Category:Options Programmer
With this option you can modify the programmer settings.
options_programmer
OPTION
DESCRIPTION
Programmer
Select one from the list.
Play sound
Name of a WAV file to be played when programming is finished.
Press the directory button to select a file.
Erase Warning
Set this option when you want a confirmation when the chip is erased.
Auto flash
Some programmers support auto flash. Pressing F4 will program the chip without showing the programmer window.
Auto verify
Some programmers support verifying. The chip content will be verified after programming.
Upload code and data
Set this option to program both the FLASH memory and the EEPROM memory
Program after compile
When compilation is successful, the chip will be programmed
Set focus to terminal emulator
When the chip is programmed, the terminal emulator will be shown
Parallel printer port programmers
LPT address
Port address of the LPT that is connected to the programmer.
Port delay
An optional delay in uS. It should be 0. But on some systems a delay might be needed.
Serial port programmer
COM port
The com port the programmer is connected to.
STK500 EXE
The path of stk500.exe. This is the full file location to the files stk500.exe that comes with the STK500.
USB
For mkII and other Atmel USB programmers you can enter the serial number here. Or you can look it up from the list.
Other
Use HEX
Select when a HEX file must be sent instead of the bin file.
Program
The program to execute. This is your programmer software.
Parameter
The optional parameter that the program might need.
Use {FILE} to insert the binary filename(file.bin) and {EEPROM} to insert the filename of the generated EEP file.
When ‘Use Hex’ is checked the filename (file.hex) will be inserted for {FILE}. In all cases a binary file will be inserted for {EEPROM} with the extension .EEP
Use {CHIP} to insert the official device name of the chip. The device name is required by some programmers.
See Also
Subcategories
This category has only the following subcategory.
S
Pages in category "Options Programmer"
This category contains only the following page.
