CONFIG WAITSUART
Compiler directive that specifies that software UART waits after sending the last byte.
CONFIG WAITSUART = value
value
A numeric value in the range of 1-255.
A higher value means a longer delay in mS.
When the software UART routine are used in combination with serial LCD displays it can be convenient to specify a delay so the display can process the data.
OPEN
See OPEN example for more details.
