CONFIG RND
This option will set the randomize configuration.
CONFIG RND = 16|32
By default rnd() is created using 16 bit multiplying and division. This limits the maximum number to a word. The ___Rseed variable is a word.
When you need to have a bigger random number you can use the CONFIG RND = 32 option.
When using 32 bit resolution, only division is used to limit the number with the specified number.
Using 32 bit the ___Rseed will be a DWORD and not a WORD.
' Plot ' FT800 platform. ' Original code from http://gameduino2.proboards.com/thread/11/screen-plotting ' Comments by James Bowman: ' Sets up the whole screen as a framebuffer, in PALETTED mode, which should be good for the fractals. ' setpal() sets palette entry 'i' to a 32-bit ARGB color, and plot(x, y, i) sets a single pixel to index 'i'. ' Requires Bascom 2.0.7.8 or greater $Regfile = "M328pdef.dat" $Crystal = 8000000 $Baud = 19200 $HwStack = 80 $SwStack = 80 $FrameSize = 300 $NOTYPECHECK Config ft800=spi , ftsave=0, ftdebug=0 , ftcs=portb.2, ftpd=portb.1 Config Base = 0 Config Submode = New Config Spi = Hard, Interrupt = Off, Data_Order = Msb, Master = Yes, Polarity = Low, Phase = 0, Clockrate = 4, Noss = 1 SPSR = 1 ' Makes SPI run at 8Mhz instead of 4Mhz Config RND = 32 $Include "FT800.inc" $Include "FT800_Functions.inc" Declare Sub setup Declare Sub setpal (Byval i As Byte, Byval argb As Long) Declare Sub plot (Byval x As Integer, Byval y As Integer, Byval i As Long) dim dw as Dword dim d1 as Dword dim d2 as Dword Spiinit If FT800_Init() = 1 Then print "END" END ' Initialise the FT800 end if Setup Do d1 = rnd(Ft_DispWidth-1) d2 = rnd(Ft_DispHeight-1) plot d1, d2, rnd(255) Loop END '------------------------------------------------------------------------------------------------------------ Sub Setup '------------------------------------------------------------------------------------------------------------ Local i As Byte CmdMemset 0, 0, Ft_DispWidth * Ft_DispHeight ClearScreen BitmapLayout PALETTED, Ft_DispWidth , Ft_DispHeight BitmapSize NEAREST, BORDER, BORDER, Ft_DispWidth, Ft_DispHeight BitmapSource 0 Begin_G BITMAPS Vertex2ii 0, 0, 0, 0 UpdateScreen setpal 0, &H00000000 For i = 1 to 255 setpal i, rnd(16777216) or &Hff000000 Next End Sub ' Setup '------------------------------------------------------------------------------------------------------------ Sub SetPal (Byval i As Byte, Byval argb As Long) '------------------------------------------------------------------------------------------------------------ Local Temp1 As Long Temp1 = i * 4 Temp1 = Temp1 + Ram_Pal Wr32 Temp1 , argb End Sub ' SetPal '------------------------------------------------------------------------------------------------------------ Sub Plot(Byval x As Integer, Byval y As Integer, Byval i As Long) '------------------------------------------------------------------------------------------------------------ Local Temp1 As Long If x < Ft_DispWidth AND y < Ft_DispHeight Then Temp1 = Ft_DispWidth * y Temp1 = Temp1 + x Wr8 Temp1, i End If End Sub ' Plot
| Languages | English |
