Adding SRAM 4-port Non Multiplexed
The following information was contributed by Juergen Bitzer.
The EBI allows to use an SRAM in 4-port non multiplexed mode. This means that you need little parts but you loose 4 ports.
$regfile = "xm128a1def.dat" $crystal = 32000000 $hwstack = &H32 $swstack = &H32 $framesize = &H32 $xramstart = &H100000 $xramsize = &H080000 '------------------ ' CPU: ' ATXMEGA128A1U-AU : 2,23/100 Mouser Muss -->A1U-AU<-- sein !!! ' ATXMEGA64A1U-AU '------------------ ' SRam: ' 512 KB AS6C4008-55PCN : SRAM 4MB 2.7V-5.5V, 512KX8, PDIP32 ' 512 KB AS6C4008-55SIN : SRAM 4MB 2.7V-5.5V, 512KX8, SOP32 ' 512 KB AS6C4008-55SIN : SRAM 4MB 2.7V-5.5V, 512KX8, SOP32 '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- ' #### Four Port SRAM #### ' MODE SRAM 4Port direkt ' PortH.0 - Pin 55 /WR ' PortH.1 - Pin 56 /RD ' PortE.4 - Pin 39 /CS0 / A16 -> CS0: SRAM 512 KB ' PortE.5 - Pin 40 /CS1 / A17 -> CS1: unbenutzt ' PortE.6 - Pin 41 /CS2 / A18 -> CS2: unbenutzt ' PortE.7 - Pin 42 /CS3 / A19 -> CS3: unbenutzt ' PortJ.0 - Pin 65 D0 -> SRam ' PortJ.1 - Pin 66 D1 -> SRam ' PortJ.2 - Pin 67 D2 -> SRam ' PortJ.3 - Pin 68 D3 -> SRam ' PortJ.4 - Pin 69 D4 -> SRam ' PortJ.5 - Pin 70 D5 -> SRam ' PortJ.6 - Pin 71 D6 -> SRam ' PortJ.7 - Pin 72 D7 -> SRam ' PortK.0 - Pin 75 A0 -> SRam ' PortK.1 - Pin 76 A1 -> SRam ' PortK.2 - Pin 77 A2 -> SRam ' PortK.3 - Pin 78 A3 -> SRam ' PortK.4 - Pin 79 A4 -> SRam ' PortK.5 - Pin 80 A5 -> SRam ' PortK.6 - Pin 81 A6 -> SRam ' PortK.7 - Pin 82 A7 -> SRam ' PortF.0 - Pin 45 A8 -> SRam ' PortF.1 - Pin 46 A9 -> SRam ' PortF.2 - Pin 47 A10 -> SRam ' PortF.3 - Pin 48 A11 -> SRam ' PortF.4 - Pin 49 A12 -> SRam ' PortF.5 - Pin 40 A13 -> SRam ' PortF.6 - Pin 41 A14 -> SRam ' PortF.7 - Pin 42 A15 -> SRam ' PortH.2 - Pin 57 A16 -> SRam ' PortH.3 - Pin 58 A17 -> SRam ' PortH.4 - Pin 59 A18 -> SRam ' PortH.5 - Pin 60 A19 - unbenutzt ' PortH.6 - Pin 61 A20 - unbenutzt ' PortH.7 - Pin 62 A21 - unbenutzt '------------------------------------------------------------------------------- '----------generate a 32 MHz system clock by use of the PLL (2MHz * 23 = 46MHz) Config Osc = Disabled , Extosc = Enabled 'Set the Multiplication factor and select the clock Reference for the PLL 'Osc_pllctrl = &B00_0_10100 '2MHz clock Source and Multiplication factor = 23 ' 00 : 2 MHz internal OSC ' 01 : Reerved ' 10 : 32 MHz internal OSC ' 11 : External Clock Source ' 1 : 0=PLL-Output devided by 1 |1=PLL-Output devided by 2 ' xxxxx: Multiplikation of PLL 1-31 Osc_pllctrl = &B11_0_01000 : Const Mhz = 32 ' 32 MHz 'enable PLL Set Osc_ctrl.4 'PLL enable 'configure the systemclock Config Sysclock = Pll 'use PLL '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8 Open "com1:" For Binary As #1 ' Termninal initialisieren Printbin #1 , &H1B ; &H5B ; &H30 ; &H6D ' All attributes off(normal) Printbin #1 , &H1B ; &H5B ; &H32 ; &H4A ' Bildschirm löschen Printbin #1 , &H1B ; &H5B ; &H48 ; ' Cursor Home Printbin #1 , &H1B ; &H5B ; &H3F ; &H32 ; &H35 ; &H68 ; ' Cursor an '------------------------------------------------------------------------------- ' Einstellungen externer Speicher ' Alle EBI-Ports müssen auf OUTPUT ' ALLE Ports, die ATKIV-LOW sind müssen auf 1 gesetzt werden !!! ' ALLE Ports, die ATKIV-HIGH sind müssen auf 0 gesetzt werden !!! Print #1 , "Config Ports for external Adress / Data-Bus with no ALE... "; Portj_dirset = &B1111_1111 : Portj = &B0000_0000 ' D0:7 Portj_pin0ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin1ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin2ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin3ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin4ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin5ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin6ctrl = &B0_0_000_000 'Totem (PushPull) Portj_pin7ctrl = &B0_0_000_000 'Totem (PushPull) Portk_dirset = &B1111_1111 : Portk = &B1111_1111 ' A0:7 Portk_pin0ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin1ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin2ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin3ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin4ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin5ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin6ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portk_pin7ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper ' PortX_pinYctrl = &B0_0_001_000 : X= Port A... Y= Bit Nr. 0-7 ' X :7 : 0= SlewRate normal, 1= SlewRate limited ' X :6 : 0= IO normal, 1= IO inverted ' XXX :5:3: 000 = Totem (PushPull) ' XXX :5:3: 001 = Totem + Buskeeper ' XXX :5:3: 010 = Totem + Pulldown on Input ' XXX :5:3: 011 = Totem + PullUp on Input ' XXX :5:3: 100 = Wired or ' XXX :5:3: 101 = Wired and ' XXX :5:3: 110 = Wired Or + PullDown ' XXX :5:3: 111 = Wired And + PullUp ' XXX:2:0: 000 = Both edges trigger port Interrupts / Events ' XXX:2:0: 001 = Rising edge trigger port Interrupts / Events ' XXX:2:0: 010 = Falling edge trigger port Interrupts / Events ' XXX:2:0: 011 = Low Level trigger port Interrupts / Events ' XXX:2:0: 100 = Reserved ' XXX:2:0: 101 = Reserved ' XXX:2:0: 110 = Reserved ' XXX:2:0: 111 = Input Buffer Disabled (Only Port A to F) for use with ADC or AC Portf_dirset = &B1111_1111 : Portf = &B1111_1111 ' A8:15 Portf_pin0ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin1ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin2ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin3ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin4ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin5ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin6ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Portf_pin7ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_dirset = &B1111_1111 : Porth = &B1111_1111 ' WR, RD , A16, A17, A18, A19, A20, A21 Porth_pin0ctrl = &B0_0_000_000 'Totem (PushPull) Porth_pin1ctrl = &B0_0_000_000 'Totem (PushPull) Porth_pin2ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_pin3ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_pin4ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_pin5ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_pin6ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porth_pin7ctrl = &B0_0_001_000 'Totem (PushPull) + Buskeeper Porte_dirset = &B1111_1111 : Porte = &B1111_0000 ' CS3, CS2, CS1, CS0 Porte_pin0ctrl = &B0_0_000_000 'Totem (PushPull) CS3 Porte_pin1ctrl = &B0_0_000_000 'Totem (PushPull) CS2 SRAM Porte_pin2ctrl = &B0_0_000_000 'Totem (PushPull) CS1 SRAM Porte_pin3ctrl = &B0_0_000_000 'Totem (PushPull) CS0 TFT Porte_pin4ctrl = &B0_0_000_000 'Totem (PushPull) Porte_pin5ctrl = &B0_0_000_000 'Totem (PushPull) Porte_pin6ctrl = &B0_0_000_000 'Totem (PushPull) Porte_pin7ctrl = &B0_0_000_000 'Totem (PushPull) ' EBI-OUT legt die 4 ChipSelect's auf einen anderen Port, damit die Adressleitungen ' A16 bis A21 auf Port-H frei wird. Portcfg_ebiout = &B0000_00_11 ' XXXX : RESERVED ' -> 00 : EBI Port3 adress output on PORT-F 0..7: SD: 4'h0, A[11:8] - SR or SR-LPC with SD on CS3: A[23:16] - SR NoAle or ALE1: A[15:8] ' 01 : EBI Port3 adress output on PORT-E 0..7: SD: 4'h0, A[11:8] - SR or SR-LPC with SD on CS3: A[23:16] - SR NoAle or ALE1: A[15:8] ' 10 : EBI Port3 adress output on PORT-F 4..7: SD: A[11:8] - SR or SR-LPC with SD on CS3: A[19:16] - SR NoAle or ALE1: --- ' 11 : EBI Port3 adress output on PORT-E 4..7: SD: A[11:8] - SR or SR-LPC with SD on CS3: A[19:16] - SR NoAle or ALE1: --- ' 00 : EBI CS-output on PORT-H 4..7 ' 01 : EBI CS-output on PORT-L 4..7 ' 10 : EBI CS-output on PORT-F 4..7 ' -> 11 : EBI CS-output on PORT-E 4..7 Ebi_ctrl = &B01_00_11_10 'SRAM ALE12, 3Port ' XX : 00: 4 Bit Data Bus ' XX -> : 01: 8 Bit Data Bus ' XX : 10: RESERVED ' XX : 11: RESERVED ' XX -> : 00: LPC-Mode: ALE1 ' XX : 01: LPC-Mode: RESERVED ' XX : 10: LPC-Mode: ALE12 ' XX : 11: LPC-Mode: RESERVED ' XX : 00: ALE1 - Adressbyte 0 and 1 multiplexed ' XX : 01: ALE2 - Adressbyte 0 and 2 multiplexed ' XX : 10: ALE12- Adressbyte 0,1 and 2 multiplexed ' -> XX : 11: NOALE- No adress multiplexing ' XX: 00: Externer Bus disabled ' XX: 01: 3 Port Control-Bus # Data-Bus # A0:A7 und A8:A15 über ALE1 gemuxt ' -> XX: 10: 4 Port ' XX: 11: 2 Port '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- '------------------------------------------------------------------------------- 'ChipSelect0 für 512 KByte SRam ' xxxxxxxx xxxx---- ' Bit: 23 bis 12 11 bis 0 nicht verwendet ' | | Ebi_cs0_baseaddr = &B00010000_00000000 ' Start &H100000 = 1M ' 00000000_00100000_00000000 = &H002000 = 8K ' 00000000_00110000_00000000 = &H003000 = 12K ' 00000000_01000000_00000000 = &H004000 = 16K ' 00000000_10000000_00000000 = &H008000 = 32K ' 00000001_00000000_00000000 = &H010000 = 64K ' 00000010_00000000_00000000 = &H020000 = 128K ' 00000100_00000000_00000000 = &H040000 = 256K ' 00001000_00000000_00000000 = &H080000 = 512K ' -> 00010000_00000000_00000000 = &H100000 = 1M ' 00100000_00000000_00000000 = &H800000 = 2M ' 01000000_00000000_00000000 = &H800000 = 4M ' 10000000_00000000_00000000 = &H800000 = 8M Ebi_cs0_ctrla = &B0_01011_01 ' Size &H080000 = 512 KB ' X : RESERVED ' XXXXX : AdressBlockSize ' 00000 : 256 Byte ' 00001 : 512 Byte ' 00010 : 1 KByte ' 00011 : 2 KByte ' 00100 : 4 KByte ' 00101 : 8 KByte ' 00110 : 16 KByte ' 00111 : 32 KByte ' 01000 : 64 KByte ' 01001 : 128 KByte ' 01010 : 256 KByte ' -> 01011 : 512 KByte ' 01100 : 1 MByte ' 01101 : 2 MByte ' 00110 : 4 MByte ' 01111 : 8 MByte ' 10000 : 16 MByte ' XX : ChipSelectMode ' 00 : disabled ' -> 01 : Enabled for SRAM ' 10 : Enabled for SRAM LPC (LowPinCount) ' 11 : Enabled for SD-SRAM Ebi_cs0_ctrlb = &B00000_100 ' je nach Geschwindigkeit des SRam's ' XXXXX : RESERVED ' XXX : Waitstates ' 000 : 0 Waitstates ' 001 : 1 Waitstates ' 010 : 2 Waitstates ' 011 : 3 Waitstates ' -> 100 : 4 Waitstates ' 101 : 5 Waitstates ' 110 : 6 Waitstates ' 111 : 7 Waitstates '------------------------------------------------------------------------------- ' Nun kann das externe SRam genauso wie das interne SRam angesprochen werden. ' Vorteil: erheblich schneller im Zugriff, wie DRam !!! ' So kann auch Hardware "memory-mapped" eingebunden werden ' oder ein ISA-Bus realisiert werden. ' Now you can use the external SRAM just like the internal SRAM. ' This is much faster like DRAM ' This way you can also map hardware and access registers as you would do for SRAM $xramstart = &H100000 $xramsize = &H080000
| Languages | English |
