Controlling and monitoring of dryer
From MCS Wiki
Description
Here is little project, which in the next once proves the superiority a controller AVR on rest processor.
This project was designed to control and monitoring the environmental conditions of a dryer that includes a set of sensors for measuring temperature and humidity. Two types of temperature sensors are used, SHT15 for ambient temperature measurement and MLX90614 to measure the surface temperature of the heater and the food.
Sensors
The SHT15 sensor has capable of measuring temperature and humidity simultaneously. With integrated circuit technology, this sensor is able to measure accurately. While the MLX90614 sensor is using infrared technology to accurately measure temperature from a distance.
Microcontroller and lcd board
 The microcontroller used is an ATMega 16-16PU, with a 11059200 Mhz Xtal oscillator. On the schematic are showed inter-connections between micro controller, ISP connector, MLX90614 Sensors, SHT15 sensor and a standard LCD display with 4 lines of 20 characters. As this schematic is also used on some others applications, there is some resistors added on it. This in order to share the programmer pins with the lcd, to have a maximum of microcontroller pins available free. There are some more resistors: they are used to avoid microcontroller output shorts in others uses of this board, and also as connections straps on the pcb. Except that there is nothing of special to said on this “classic” schematic (don’t forget the decoupling capacitors!). It is normally possible to use any other AVR microcontroller and board already available (with the same microcontroller or equivalent), To do that, it will be necessary to change the relevant initialization parameters on the Bascom program. No tests have been done with any other board.
Schematic
Schematic
BASCOM Code
$regfile = "m16def.dat" ' specify the used micro
$crystal = 11059200 ' used crystal frequency
$baud = 38400 ' use baud rate
'.................................................LCD Configuration....................................................
Config Lcdpin = Pin , Db4 = Porta.2 , Db5 = Porta.3 , Db6 = Porta.4 , Db7 = Porta.5 , E = Porta.1 , Rs = Porta.0
Config Lcd = 20 * 4
Config Lcdbus = 4
'.....................................................Variable...........................................................
Dim Interval As Byte , Settemp As Single , Settemptime As Word , Speed As Single , Z As Single
Dim Kbd As Byte , I As Byte , S(5) As String * 3 , B As Single , C As Single , K As Single
Dim Dama As String * 8 , A As Byte , Minute As Byte , Hour As Byte , Fruittemp As Single
Dim Tin As Single , Tout As Single , Rin As Single , Rout As Single , Heatertemp As Single
Dim Adres As Byte , Value As Byte , Temp As Single , Tempword As Word , U As Single
Dim Ctr As Byte , Dataword As Word , Command As Byte , Dis As String * 20 , Calc As Single
Dim Calc2 As Single , Rhlinear As Single , Rhlintemp As Single , Tempc As Single , Tempf As Single
Dim M As Word , Tamp As Single , Pamp As Single , Key As Byte
'...................................................Sub function...........................................................
Declare Sub Read_ram1(byval Adres As Byte , Value As Byte)
Declare Sub Read_ram2(byval Adres As Byte , Value As Byte)
Declare Sub Getit1
Declare Sub Getit2
'...................................................Interrupt........................................................
Config Clock = Soft 'This command inits the clock
Config Date = Ymd , Separator = - ' ANSI-Format
Date$ = "12-02-26"
Time$ = "20:35:00"
Input "Enter the time (hh:mm:ss):" , Time$
Input "Enter the date (mm/dd/yy):" , Date$
Config Porta.6 = Output ' Lcd intialization
Config Porta.7 = Output ' Heater output
'....................................................sensor configuration............................................
Config Scl = Portc.0
Config Sda = Portc.1
Const Addressw1 = &B00001000 'slave write address, slave address is 4
Const Addressr1 = &B00001001 'slave read address ,slave address is 4
Const Addressw2 = &B00000110 'slave write address, slave address is 3
Const Addressr2 = &B00000111 'slave read address ,slave address is 3
Const C1 = -4
Const C2 = 0.0405
Const C3 = -0.0000028
Const T1c = .01
Const T2 = .00008
Const T1f = .018
Sck Alias Portc.2
Dataout1 Alias Portc.3
Datain1 Alias Pinc.3
Dataout2 Alias Portc.4
Datain2 Alias Pinc.4
Ddrc = &B11111111 'all port C are output
Config Pinc.2 = Output 'sck
Config Pinc.3 = Output
Config Pinc.4 = Output 'datain
' .............................................LCD Configuration......................................................
Set Porta.6
Cls
Cursor Off
Wait 1
Cls
Deflcdchar 0 , 32 , 32 , 32 , 25 , 26 , 4 , 11 , 19 ' Precent
Deflcdchar 1 , 24 , 24 , 32 , 15 , 8 , 8 , 8 , 15 ' Centigerad
'reset the serial communications first, it is easily confused!
Set Dataout1
Set Dataout2
For Ctr = 1 To 12
 Set Sck
 Waitus 2
 Reset Sck
 Waitus 2
Next Ctr
Cls
Cursor Off
'.......................................main program................................................................
'........................................time display..................................................................
Locate 1 , 1
 Lcd Time$
Locate 1 , 11
 Lcd "20"
Locate 1 , 13
 Lcd Date$
 'Waitms 250
'...........................................................sensors...................................................
 'MLX1
 Call Read_ram1(&B00000110 , Value) :
 Temp = Tempword * 0.02
 Temp = Temp - 273.15
 Dama = Fusing(temp , "##.##")
 Locate 2 , 1
 'Lcd "A=" ; Dama ; Chr(1) 'print T ambiant
 Call Read_ram1(&B00000111 , Value) :
 Heatertemp = Temp
 Locate 2 , 11
 Lcd "Ht=" ; Dama ; Chr(1) 'again for T object
 'MLX2
 Call Read_ram2(&B00000110 , Value) :
 Locate 1 , 1
 Call Read_ram2(&B00000111 , Value) :
 Fruittemp = Temp
 Locate 2 , 1
 Lcd "Fr=" ; Dama ; Chr(1) 'again for T object
 'SHT1
 Command = &B00000011
 Call Getit1 'Get the temperature, puts result in "dataword" for us
 Tempf = T1f * Dataword
 Tempf = Tempf - 40
 Tempc = T1c * Dataword 'get celcius for later calculations and for "the rest of the world"
 Tempc = Tempc - 40
 Tout = Tempc
 Dis = Fusing(tempc , "###.##")
 Locate 3 , 11
 Lcd "Out=" ; Dis ; Chr(1) ' print T ambiant
 'SHT2
 Call Getit2 'Get the temperature, puts result in "dataword" for us
 Tempf = Tempf - 40
 Tempc = Tempc - 40
 Tin = Tempc
 Locate 3 , 1
 Lcd "In=" ; Dis ; Chr(1) ' print T ambiant
 ' SHT1
 Command = &B00000101
 Call Getit1 'get the humidity
 Calc = C2 * Dataword
 Calc2 = Dataword * Dataword 'that "2" in the datasheet sure looked like a footnote for a couple days, nope it means "squared"!
 Calc2 = C3 * Calc2
 Calc = Calc + C1
 Rhlinear = Calc + Calc2
 'Dis = Fusing(rhlinear , "##.##")
 'Print "Humidity adjusted for linear = " ; Dis
 Calc = T2 * Dataword
 Calc = Calc + T1c
 Calc2 = Tempc - 25
 Calc = Calc2 * Calc
 Rhlintemp = Calc + Rhlinear
 Rhlintemp = Tempc / 10.0
 Rhlintemp = Rin + Rhlintemp
 Dis = Fusing(rhlintemp , "##.##")
 Locate 4 , 11
 Lcd "Out=" ; Dis ; Chr(0) 'print Humudity
 'SHT2
 Call Getit2 'get the humidity
 Calc2 = C3 * Calc2
 Calc = Calc + C1
 Calc = Calc + T1c
 Calc2 = Tempc - 25
 Calc = Calc2 * Calc
 Rin = Rhlintemp
 Locate 4 , 1
 Lcd "In=" ; Dis ; Chr(0) 'print Humudity
'......................................heater control......................................
M = _hour * 60
M = M + _min
If Settemptime =< M And Settemp >= Heatertemp Then
 Set Porta.7
 Else
 Reset Porta.7
 '.....................................sending control....................................
C = _sec. / Interval
B = Round(c)
If B = C Then 'And K = Z
If Key <= 5 Then
Pamp = 0.008
Tamp = Key * 0.00015
Tamp = Tamp + 0.035
Elseif Key =< 6 And Key > 5 Then
Pamp = 0.021
Tamp = Tamp + 0.035
Elseif Key > 6 And Key < 10 Then
Pamp = Key * 0.01
Tamp = Tamp + 0.035
Elseif Key >= 10 And Key < 20 Then
U = Key + 3
Pamp = U * 0.01
Tamp = U * 0.00015
Tamp = Tamp + 0.035
Elseif Key >= 20 Then
U = Key + 6
Pamp = U * 0.01
Tamp = U * 0.00015
Tamp = Tamp + 0.035
 Print Spc(2) ; Time$ ; Spc(3) ; "Ht=" ; Fusing(heatertemp , "#.##") ; Spc(5) ; "Ft=" ; Fusing(fruittemp , "#.##")_
 ;spc(10) ; "Tin=" ; Fusing(tin , "#.##") ; Spc(10) ; "Tout=" ; Fusing(tout , "#.##")
 Print ; Spc(2) ; "RHin=" ; Fusing(rin , "#.##") ; Spc(2) ; "RHout=" ; Fusing(rout , "#.##")_
 ;Spc(2) ; "Taskamper=" ; Fusing(tamp , "#.###") ; Spc(2) ; "PowerAmper=" ; Fusing(pamp , "#.###")
 Print
'...........................................sample of reading a byte from Ram...........................................
 Tempword = 0
 I2cstart 'generate start
 I2cwbyte Addressw1 'slave adsress(write)
 I2cwbyte Adres 'address of EEPROM or commend
 I2cstart 'repeated start
 I2cwbyte Addressr1 'slave address (read)
 I2crbyte Value , Ack
 Tempword = Value
 Shift Tempword , Left , 8
 Tempword = Tempword Or Value
 I2cstop 'generate stop
Rotate Tempword , Left , 8
End Sub
 Tempword = 0
 I2cwbyte Addressw2 'slave adsress(write)
 I2cwbyte Addressr2 'slave address (read)
 Tempword = Value
End Sub
Sub Getit1
 Local Datavalue As Word
 Local Databyte As Byte
 'start with "transmission start"
 Set Sck
 Reset Dataout1
 Reset Sck
 Set Sck
 Set Dataout1
 Reset Sck
 'now send the command
 Shiftout Dataout1 , Sck , Command , 1
 Ddrc = &B11110111 'datain is now input
 Config Pinc.3 = Input 'datain
 Set Sck 'click one more off
 Reset Sck
 Waitus 10 'no idea why, but it doesn't work without it!
 Bitwait Pinc.3 , Reset 'wait for the chip to have data ready
 Shiftin Datain1 , Sck , Databyte , 1 'get the MSB
 Datavalue = Databyte
 Ddrc = &B11111111
 Reset Dataout1 'this is the tricky part- Lot's of hair pulling- have to tick the ack!
 Set Sck
 Reset Sck
 Shiftin Datain1 , Sck , Databyte , 1 'get the LSB
 Shift Datavalue , Left , 8
 Datavalue = Datavalue Or Databyte
 'don't tick the clock or ack since we don't need the CRC value, leave it hanging!
 Dataword = Datavalue
 Ddrc = &B11111111
 Reset Dataout1
 Set Sck
 Reset Sck
 Shiftin Datain1 , Sck , Databyte , 1 'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
 'Print "CRC value was - " ; Databyte
 Ddrc = &B11111111
 Set Dataout1
 Set Sck
 Reset Sck
End Sub
Sub Getit2
 Set Sck
 Reset Dataout2
 Reset Sck
 Set Sck
 Set Dataout2
 Reset Sck
 Shiftout Dataout2 , Sck , Command , 1
 Ddrc = &B11101111 'datain is now input
 Config Pinc.4 = Input 'datain
 Reset Sck
 Bitwait Pinc.4 , Reset 'wait for the chip to have data ready
 Shiftin Datain2 , Sck , Databyte , 1 'get the MSB
 Ddrc = &B11111111
 Reset Dataout2 'this is the tricky part- Lot's of hair pulling- have to tick the ack!
 Set Sck
 Reset Sck
 Shiftin Datain2 , Sck , Databyte , 1 'get the LSB
 Ddrc = &B11111111
 Reset Dataout2
 Set Sck
 Reset Sck
 Shiftin Datain2 , Sck , Databyte , 1 'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
 Ddrc = &B11111111
 Set Dataout2
 Set Sck
 Reset Sck
End Sub
Author
Written by: Mohammad Jafar Dalvand , Iran, University of Tehran
Email Address: Dalvand@ut.ac.ir
