Getting started with Arduino UNO R3 and Ethernet Shield (W5100)
Please read first this Article:
Getting started with Arduino and WIZ820io http://wiki.mcselec.com/Getting_started_with_Arduino_and_WIZ820io
It uses the same source code exept we use here an Wiznet W5100 Chip intead of W5200 so only config TCPIP needs to be changed.
The usage of Easy TCP/IP in combination with that example is also the same.
The used Ethernet Shield is this here: http://arduino.cc/en/Guide/ArduinoEthernetShield
Another difference is that in this example we do not use the Bascom-AVR bootloader. We use here the existing Arduino bootloader.
To get started with this see here: http://wiki.mcselec.com/Getting_started_with_Arduino_UNO
Source Code:
The difference is only this part in the Bascom source code:
'Here you need MAC address, the ip address you like to use, subnet mask, gateway and localport Config Tcpip = Noint , _ Mac = 1.1.94.127.1.255 , _ Ip = 192.168.2.254 , _ Submask = 255.255.255.0 , _ Gateway = 192.168.2.1 , _ Localport = 1000 , _ Tx = $55 , Rx = $55 , _ Chip = W5100 , _ Spi = 1
Complete Source code:
' IP Address of Arduino = 192.168.2.254 ' Port of Arduino = 1000 ' We use UDP ' 'Use Hardware: ' - Arduino UNO R3 ' - Arduino Ethernet Shield with W5100 Wiznet Chip ' NTP Server IP address (here you can change the NTP server of your choice) Const Ntp1 = 192 : Const Ntp2 = 53 : Const Ntp3 = 103 : Const Ntp4 = 108 ' Example = 192.53.103.108 Const Use_ping = 1 'use PING NTP server for checking NTP server availability before move on $regfile = "m328pdef.dat" $crystal = 16000000 '16MHz $hwstack = 100 $swstack = 100 $framesize = 400 Config Com1 = 57600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0 '------------------------------------------------------------------------------- ' Server Variables '------------------------------------------------------------------------------- Dim Ip_sntp_server As Long 'assign the IP number of a SNTP server Ip_sntp_server = Maketcp(ntp1 , Ntp2 , Ntp3 , Ntp4) 'assign IP of NTP SERVER Wait 2 Print Print "-----START Arduino UNO R3 + Ethernet Shield DEMO-----" '------------------------------------------------------------------------------- ' Network Hardware '------------------------------------------------------------------------------- Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0 Spiinit Print Enable Interrupts 'Here you need MAC address, the ip address you like to use, subnet mask, gateway and localport Config Tcpip = Noint , _ Mac = 1.1.94.127.1.255 , _ Ip = 192.168.2.254 , _ Submask = 255.255.255.0 , _ Gateway = 192.168.2.1 , _ Localport = 1000 , _ Tx = $55 , Rx = $55 , _ Chip = W5100 , _ Spi = 1 '------------------------------------------------------------------------------- ' Config Clock '------------------------------------------------------------------------------- Dim Local_time As Long Dim New_second As Bit Config Date = Dmy , Separator = . Config Clock = User Config Timer1 = Timer , Prescale = 256 On Timer1 Timer_irq Saveall 'the SAVEALL option is NEEDED ! Const Timer_preload = 3036 Enable Timer1 '------------------------------------------------------------------------------- ' UDP '------------------------------------------------------------------------------- Dim Idx As Byte ' socket number Dim Result As Word ' result Dim S(255) As Byte Dim R(255) As Byte Dim Sstr As String * 255 Dim Temp As Byte , Temp2 As Byte ' temp bytes Dim Ip As Long '------------------------------------------------------------------------------- ' PING NTP SERVER to check if NTP server is available '------------------------------------------------------------------------------- #if Use_ping = 1 Dim J As Byte , Res As Byte Dim Ii As Byte Dim Ping_check_ok As Bit ' FILL PING ARRAY S(1) = 8 'type is echo S(2) = 0 'code S(3) = 0 ' for checksum initialization S(4) = 0 ' checksum S(5) = 0 ' a signature can be any number S(6) = 1 ' signature S(7) = 0 ' sequence number - any number S(8) = 1 S(9) = 65 Dim W As Word At S + 2 Overlay 'same as dta(3) and dta(4) Dim B As Byte W = Tcpchecksum(s(1) , 9) ' calculate checksum and store in dta(3) and dta(4) 'Ip = Maketcp(192.53.103.108) 'try to check this google server Print "PING NTP Server : " ; Ip2str(ip_sntp_server) 'Print "Socket " ; Idx ; " " ; Idx Setipprotocol Idx , 1 'set protocol to 1 'the protocol value must be set BEFORE the socket is openend Idx = Getsocket(idx , Sock_ipl_raw , 5000 , 0) 'RAW Socket ' We try the PING 3 times (but if we get an answer we exit the for loop) Do Incr Ii Result = Udpwrite(ip_sntp_server , 7 , Idx , S(1) , 9) 'write ping data ' Print "Ping Number : " ; ii Waitms 200 ' depending on the hops, speed, etc Result = Socketstat(idx , Sel_recv) 'check for data ' Print "REC:" ; Result If Result >= 11 Then Res = Tcpread(idx , R(1) , Result) 'get data with TCPREAD !!! ' Print "DATA RETURNED :" ; Res '( ' For J = 1 To Result Print R(j) ; " " ; Next Print ') Print "PING OK --> Exit Do..Loop" Set Ping_check_ok Exit Do ' If we can an answer from NTP Server exit do ... loop Else Print "NTP Server not available" End If Waitms 100 Loop Until Ii = 3 Ii = 0 #else Dim Ping_check_ok As Bit Ping_check_ok = 1 #endif '------------------------------------------------------------------------------- ' SNTP '------------------------------------------------------------------------------- If Ping_check_ok = 1 Then 'When the NTP Serverer responded to PING 'we need to get a socket first 'note that for UDP we specify sock_dgram Idx = Getsocket(idx , Sock_dgram , 1000 , 0) ' get socket for UDP mode, specify port Print "Socket " ; Idx ; " " ; Idx Local_time = Sntp(idx , Ip_sntp_server) ' get time from SNTP server Print "Local_time = " ; Local_time If Local_time < 100 Then 'try it again Wait 1 Local_time = Sntp(idx , Ip_sntp_server) ' get time from SNTP server Print "Second try ; Local_time = " ; Local_time End If Local_time = Local_time + 3600 ' (UTC/GMT) time + 3600 Print Date(local_time) ; Spc(3) ; Time(local_time) End If 'get a socket first 'note that for UDP we specify sock_dgram Idx = Getsocket(idx , Sock_dgram , 1000 , 0) ' get socket for UDP mode, specify port 'Print "Socket " ; Idx ; " " ; Idx Do If New_second = 1 Then Reset New_second 'Do something every second ...... End If 'The UDP header give us info about Peersize, Peerport and peeraddress 'which is the amount of data bytes received from peerport and peer ip address Udpreadheader Idx ' read the udp header (only the first 8 Bytes) If Peersize > 0 Then ' the actual number of bytes (without header bytes) Print "Size= " ; Peersize ; " By" ; " Port= " ; Peerport ; " Sender IP= " ; Ip2str(peeraddress) ; " Timestamp : " ; Date$ ; " / " ; Time$ Temp = Udpread(idx , S(1) , Peersize) ' read the number of Bytes into Array S Print "DATA = " ; For Temp = 1 To Peersize Print Chr(s(temp)) ; ' print what we have received over USART to debug interface Next Print 'Send it back to sender IP, Sender Port Result = Udpwrite(peeraddress , Peerport , Idx , S(1) , Peersize) ' write the received data back End If Loop End Timer_irq: Incr Local_time Time$ = Time(local_time) Date$ = Date(local_time) Set New_second Return Getdatetime: Return Settime: Return Setdate: Return
to know how to use this example code.
Terminal Output of example:
When using Easy TCP/IP and sending the text "Hello".
PING NTP Server : 192.53.103.108
Ping Number : 1
Socket 0 0
Local_time = 416063775
08.03.13 14:16:15
Size= 5 By Port= 50000 Sender IP= 192.168.2.100 Timestamp : 08.03.13 / 14:16:45
DATA = Hello
Author
MAK3
