BAUD1
(Redirected from BAUD1-BAUDx)
Changes the baud rate for the second hardware UART.
BAUD1 = var
BAUD1 #x , const
Xmega Syntax
BAUDx = constant
The baud rate that you want to use.
X
The channel number of the software UART.
Const
A numeric constant for the baud rate that you want to use.
Do not confuse the BAUD1 statement with the $BAUD1 compiler directive.
And do not confuse $CRYSTAL and CRYSTAL
$BAUD1 overrides the compiler setting for the baud rate and BAUD1 will change the current baud rate.
BAUD1 = ... will work on the hardware UART.
BAUD #x, yyyy will work on the software UART.
Xmega
For the xmega, the X represents the UART number. BAUD means, the first UART, BAUD1 the second UART, and BAUD7 is the last UART. A channel number is not supported.
For the Xmega you need to use a constant for the baud rate. Variables are not supported.
$CRYSTAL , $BAUD , $BAUD1 , BAUD
'micro : Mega162
'purpose : demonstrates BAUD1 directive and BAUD1 statement
$regfile = "M162def.dat"
$baud1 = 2400
$crystal= 14000000 ' 14 MHz crystal
Open "COM2:" For BINARY As #1
Print #1 , "Hello"
'Now change the baud rate in a program
Baud1 = 9600 '
Print #1 , "Did you change the terminal emulator baud rate too?"
Close #1
